Question about Acer Aspire 5050-3242 Notebook
Reboot I want to reboot my laptop to it's original factory settings. I have done this once before but I cannot remeber the sequence of buttons that I need to press. It is an Acer Aspire 3000. Please help!
    Genius:
  • 1,913 Answers
When u start your laptop pressDEL or F2 or F3 orF12 or F5 or tab key.
then u enter in bios.then reset factory defaults.
but if ned xp factory defaults thern press F 8 key then go to last known good configuration.
thats all.
Posted on Oct 11, 2008
How do i reset factory settings on coby mid 8042
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 07, 2014 | Coby kyros Tablets & eReaders
My Coby Kyros mid 7048 is frozen on android? How do you fix that problem?
Sep 02, 2014 | Coby Kyros 7" Touchscreen Tablet
How can i reset my passcode pattern
Aug 22, 2014 | Coby Kyros MID7120-4G 4 GB Tablet - 7" -...
How to reboot from boot sequence
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. You want to boot from the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Dell XPS M1730 Laptop
Every so often my thunderbolt will crash and reboot for no apparent reason. Is this normal or a malfunction with the phone
There are a lot of software issues with some applications that lock up the phone.
Try deleting newly downloaded applications and work backwards until your phone does not reboot again. Any paid for apps can simply be re-downloaded through the Android Market.
If this does not work, attempting a factory reset will be your next step.
Factory Reset
1) Make sure you back up all of your contacts, pictures, etc. Factory Resetting could possibly delete all data off of your microSD card, and you wouldn't want to lose any of it.
2) Once done, from the home screen tap the Menu key.
3) Tap the Settings Option.
4) Under Settings, tap Privacy
5) Select Factory Data Reset
6) Tap Reset Phone.
Once done, your phone should be restored to factory defaults.
If for some reason your phone has decided to continue crashing and rebooting, you must perform a Hard Reset. This will undoubtedly remove contact information.
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
Remember, everything will be lost from this point on; so be sure you have EVERYTHING backed up that you do not wish to disappear. This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
I have a lenovo y 430 laptop and i want to restore it to factory setting. So I start with the laptop switched off. I click on the OKR button. My laptop just boots up as normal. Once it is on, I press the...
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer.
If this fails, then call them.
http://www.lenovo.com/planetwide/select/selector.html
May 13, 2011 | Lenovo IdeaPad Y430-3231U Notebook
My daughters computer is a dell latitude D610 notebook running Windows XP.....when powering up XP starts to load and then goes to a blank blue screen....Is there a restore disc or something i can download...
Hi. I provided you a link where to download the restore disk. Once you have downloaded the restore disk, here's the instruction on how to use the disk.
Instruction:
  • Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
  • 2
    Insert the Recovery CD into your CD-ROM.
  • 3
    Reboot your computer.
  • 4
    Watch the text in DOS carefully. When prompted to boot from your CD, do so.
  • 5
    Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
  • 6
    Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
  • Nov 09, 2010 | Dell Latitude D610 Notebook
    How to reboot my sony vaio vgn-cs26t to original factory setting
    insert the first recovery disk and simply reboot your computer. instead of loading windows you will be brought to a screen where you can set up your computer to be reformatted. if the computer boots windows instead you will need to change the boot order in the bios and set the cd rom drive first. this can be done by pressing a button or button combination while the computer is booting. pay attention because you onle have a few seconds. if all else fails call sony tech support and ask them how to change your boot order
    Jul 23, 2009 | Sony VAIO VGN-CS260J/P Laptop
    Replaced 512M DDR with 2G DDR2, only sees 512M
    This often occurs as a result of fast/quickpost settings in your bios.
    You will need to shut down your system, boot it, then quickly read the black and white screen.
    Then press whatever button your system displays as the setup or bios button, generally Esc, Del, F1 or F2 but can be anything.
    Once in your BIOS just browse around until you find the setting marked Quickpost, Fastpost, Quiet Post, etc.
    When you find the setting, Disable it, save the settings and reboot. Once you're done rebooting, check the system properties. This should do the trick, then repeat the steps to re-enable the quick mode, and reboot again. It only needs to be disable for one boot sequence to allow the computer to find and add the new hardware to it's BIOS setup.
    Hope this helps FixYa,
    Chris
    May 05, 2009 | Computers & Internet
    Acer Aspire 5050-3242 Notebook Logo
    155 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
