Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Attach pedastal to whirpool duet washing machine front loader
How do yo attach the pedastal for a whirpool duet washing machine.
  • 59 Answers
You will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Posted on May 26, 2009
    Sergeant:
    Champion:
  • 214 Answers
You must first remove the drawer by lifting 2 small black plastic clips located on front left and right side on the slides.After removing the drawer there should be 4 hole on each corner of pedistal you will need screws that would fit. normally it comes with the pedistals.Then insert screws not all the way just enough to slide the holes on the pedistalon to the body of washer.Then tighten .Good luck
Posted on May 10, 2009
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What does the F 99 code mean on my whirlpool duet front loader mead
You can get error codes by going to whirpool website and entering your model and year of machine.
Apr 27, 2014 | Whirlpool Washing Machines
How do i reset the ccu in a whirpool Front loader duet wfu9400su00 with a F28 code?
F-28 is a serial communication error. either your main cntrl or motor control is going to be bad. hard to say which one without a multi meter and the machine in front of me though.
Apr 05, 2011 | Whirlpool Washing Machines
Brand new tub vibrates so bad i have to turn it off very unhappy
have you removed the shipping bolts on the back of the machine and make sure it is level and all the legs are locked.if it is attached to a pedastal then make sure that it is properly secured to the pedastal.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Washing Machine Front Loader. The
you can get your bearings by way of removing back cover first.
Aug 09, 2009 | Washing Machines
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reset the 'Conrol Lock' on a Whirpool Duet Washer?
press and hold the end of cycle signal button for 3-5 seconds
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
633 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
