Question about Dryers
Maytag gas dryer quits, will restart hours later.
I have a maytag gas dryer, ldg8420aww,that will work fine for 20 minutes or more, then just quit and will not restart. it will start fine after setting a couple hours. when it dies, it is as if there is no electric. i have not opened it up but did remove a large amount of lint
  • jrinaman Oct 18, 2008
    i cleaned a large amount of lint today, including inside motor. found bearings to be tight and oiled. everything turned much easier afterwards but still quits after 20 minutes. when trying to use earlier, the motor maid a humming noise before kicking off. i assume a new motor is needed.
  • 943 Answers
HI. thanks for your question. the problem you have is with the motor, it gets too hot and cuts out. clean lint on motor and try again thanks the appliance doc. please rank my answer. thanks
Posted on Oct 11, 2008
  • john gagnon
    john gagnon Oct 19, 2008
    yes i would say yes
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
Dryer had been working fine. A load of sheets was drying and had been for apprx.20 minutes. The dryer quit in the middle of the cycle and will not restart. There was no sound or any indicator of a problem...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 18, 2010 | Frigidaire Dryers
I have a Neptune MD5500 natural gas dryer. At startup, the igniter glows and the the burner begins but the flame quits after about 1 to 2 minutes. If it is shut down and restarted, it seems to act the...
alex
I have a MDG6700 with the same issue..all my research on this problem points to the 2 coils on the gas valve. Tomorrow i am going to change them (kit is about 30 bucks to get local)..coils test good but other postings about this dryer say one coil gets hot and is weak and close the gas valve thus stopping the heating process..
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our dryer is getting hot then it turns off 3 minutes later
When you say it turns off do you mean motor quits it that the case you motor is over heating and needs to be replace. It wll shut off for a while and then later work fine for three more minutes and do the same. If you mean it quits heating the the thermostadt is sticlking and need to be raplaced.
Apr 21, 2010 | Whirlpool LGN2000LWH Gas Dryer
Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Jul 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
Dec 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
