Question about Radio Communications
Anyone know how to get a Zonda Bluetooth Headset to go into pairing mode? Or do a reset on it?
I got a pair of Zonda Bluetooth Headset. I am unable to get it to go into pairing mode, it was a gift so it was used before. My guess is that since it was paired with another phone, it just needs a 'hard reset' to get back into pairing mode. I've tried to follow the manufactures instructions, but this does nothing. It seems to only want to go into play mode, not pairing mode. As far as I can tell the set was made in Mexico and not normally sold here in the US, other than on line discounters. Any ideas would be helpful.
Turn on the Bluetooth on your phone first and then long press the button on the headset until you see the alternate blue-red light repeating and release the button quickly. Your phone will discover the headphone now withe name "ZBT1099" pair with it and If asked for the pass key in phone give "0000". You are all set!! :)
Posted on Feb 22, 2013
SOURCE: pairing my headset with ps3
hold your power button till the light blinks blue red fast then scan select 8860 then pass key is 0000
Posted on Sep 15, 2008
SOURCE: Motorola H700 pairing
I had this problem and found you need to open the mouthpiece soon after the lights goes violet, otherwise the light starts to flash blue and you are too late and its time to start again.
Posted on May 26, 2007
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
bob_computer
  • 3153 Answers
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
Posted on Aug 08, 2009
SOURCE: pairing my Z9i v1.1 headset with my new iPhone
I had a problem with this also, try this.
Turn off both devices then turn on your phone.
make sure your bluetooth option is "ON" on your phone
turn on the blueant z9i
press and hold both volume buttons, while doing that, press the ANT button.
Your blueant should be flashing fast right now and your iphone should be able to find it.
complete the pairing by selecting the blueant headset on your iphone and enter the code "0000"
enjoy
Posted on Feb 01, 2010
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
I am using samsung bluetooth wep350 which was paired to my old i phone .now i have changed to i phone 4 .....i am unable reset the bluetooth wep350 to my new phone ....plz guide plz send to...
This headset should be in pairing mode, prior to trying to pair it with another device. The pairing mode in this headset is indicated by its light steadily lit. Starting with it turned off, if it has never been paired before, just by turning it on, it should enter the pairing mode automatically. Otherwise, press and hold the Multi-Function Button for a longer time than the time required to turn it on, until the indicator light is steadily lit. Only then, make your phone's bluetooth application search for new devices. After a little while, the WEP350 should appear on the phone' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further. Regards, Carlos
Jan 02, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
I am unable to pair my bluetooth with nokia 5310 music xpress
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Oct 16, 2009 | Nokia Bluetooth Headset BH-207 Wireless...
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
Sep 16, 2009 | LG HBM-550 Wireless Headset
Passkey
The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
Nov 14, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
1,982 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
