Question about Canon PowerShot S3 IS Digital Camera
Aperture priority and image size
I have a Canon Powershot S3 IS. I have the image size set to 2816x2112. I have the compression set to Superfine. When I shoot in Auto mode it is fine. But when I shoot in AP (I have it set to F8) the image reverts to 640x480. This seems to have happened very recently. I have been using the AP mode set to F8 for some time with the image size remaining at 2816x2112. I am assuming I must have pressed some button somewhere on the camera that has produced this result but I just can't figure out how to fix it. Please help!
  • Canon Master
  • 4,738 Answers
Auto and the other settings each have an independent image size that the camera remembers. You need to set the image size for AP. Go to AP mode and press FUNC. The image size should show up in the left menu (it may say L, M1, M2, S, standing for Large, Medium, and Small, resolution settings). Select it and choose a different size that you'd prefer (believe that you want L). Then press FUNC again to exit the menu.
Posted on Oct 12, 2008
Can't get a 2MB image. What am I doing Wrong?
Jpg images use a form of compression. If the camera sees an area that is all white for instance, it knows that that one white pixel is the same as those around it and doesn't need all the information. This reduces the size. If you have highest res and superfine compression the only other thing you can is increase physical size if the camera has that choice, or buy a Canon Rebel or Nikon D90 :>)
Apr 28, 2016 | Canon PowerShot A520 Digital Camera
Hi, I have a Canon Powershot G12. I'd like to resize the pictures smaller in the camera. Can this be done? If so, how do I do this?
To change the size of existing pictures:
Press the Playback button (right-pointing triangle). Press the MENU button and choose [RESIZE] and press FUNC/SET. Use left/right to select an image and press FUNC/SET. Use left/right to choose a size and press FUNC/SET.
To change the size the pictures are taken:
After pressing the FUNC/SET button, use up/down to select the current image size (probably displayed as a rounded triangle and a capital "L"). Use left/right to select an option. L is 10 megapixels (3648x2736), M1 is 6MP (2816x2112), M2 is 2MP (1600x1200), and S is 0.3MP (640x480).
Now, ask yourself this: If you're going to be taking 6MP or smaller pictures, why did you bother to buy a 10MP camera?
Jan 04, 2011 | Cameras
In my canon Power shot sx100is . how can i get the date on image
Good evening!
Bad news. For the date embedded feature, the image size is FIXED to the 2M (1600x1200) setting with the compression set to Fine.
The only other way I can think of, is if you are printing from software that came with your camera. When you start the software and transfer your photos, there will be a box to check if you want to add a date stamp to your photos.
Sorry about that! Mine does the same thing, only I never put the stamp on mine.
Hope this will be ok!
Oct 25, 2009 | Canon PowerShot SX100 IS Digital Camera
Megapixels on camera needs to be reset?
You can check the user manual to change again the resolution settings, or just reset the camera to the factory settings through the menu settings (last and bottom setting option).
Best regards,
May 28, 2009 | Canon PowerShot S3 IS Digital Camera
Grainy movies
Go to menu and select images quality
There are three settings for quality, SuperFine, Fine, and Normal. Movies can be capture at 640x480 and 320x240 at 30 fps and 15 fps.
Jan 24, 2009 | Canon PowerShot A620 Digital Camera
How do I adjust the resolution that the photos are saved?
To change the resolution and compression:
1. Press the Func button.
2. Scroll down, if necessary, to the icon in the lower left corner of the LCD.
3. Use the right or left arrows to select L (large), M1, M2 (medium), or S (small). Press the Set button.
4. Use the right or left arrows to select superfine (quadrant with S), fine (quadrant), or normal (stairsteps). Press the Set button.
5. Press the Func button to exit.
Large/superfine images will take up the most space on the memory card. Small/normal images will take the least, but the picture quality will be less if you're printing the pictures.
There is a table at this link (scroll down) to show you how many images will fit on a memory card at different settings.
May 09, 2008 | Canon PowerShot S1 IS Digital Camera
Low resolution/pixels on "auto" mode
Download the user manual HERE and it will tell you exactly how to change the setting.
Is an easy fix when you know it
May 02, 2008 | Canon PowerShot S3 IS Digital Camera
Canon Powershot S5IS Aperture
Hey Kate
I have owned a Canon Powershot S5 since launch last year and I take a lot of photos with blurred background. I select AV on the dial (Aperture priority) and set aperture to between 2.7 and about 4.0 max, depending on how much depth of field I want and what my subject is.
This setting blurs the background beautifully.. Just remember that an aperture of 2.7 will give you a very shallow depth-of-field, so if focus on face is important, make sure you have face recognition set to ON.
I hope this helps
Apr 04, 2008 | Canon PowerShot S5 IS Digital Camera
Need higher resolution by tomorrow
For the best resolution, use your FUNC button at the back of your camera. Scroll down on the left hand side to the bottom of the menu which starts with AWB, Set your size of image to 3264x2448 and then using the SET button, select S, which is superfine
Feb 14, 2008 | Canon PowerShot S5 IS Digital Camera
Power shot A95
It is the setting on your camera ,if you set at (2592x1944) superfine ,you were only can take 11 picture.So if you want to take more pictures ,try set to lower resolution. Below is the setting table: Reso Quality Approx.file size # images on 32MB card Large (2592 x 1944) Superfine 2.4 MB 11 Fine 1.4 MB 21 Normal 695 KB 43 Medium 1 (2048 x 1536) Superfine 1.6 MB 18 Fine 893 KB 33 Normal 445 KB 67 Medium 2 (1600 x 1200) Superfine 1002 KB 30 Fine 558 KB 54 Normal 278 KB 107 Small (640 x 480) Superfine 249 KB 119 Fine 150 KB 195 Normal 84 KB 336
Aug 04, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
118 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
