Question about Uniden BC72XLT Handheld Scanner
How to program an old regency 1060 scanner
I came a cross an old regency r1060 scanner and would like to teach my 9 year some things about radio waves and signals, but I can't program the thing... does anyone know about this model?
  • 74 Answers
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Posted on Oct 11, 2008
Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Jul 11, 2011 | Radio Shack Pro-96 Scanner
How do I delete channels off of my pro-135 handheld scanner?
To RESET the scanner and delete ALL programmed frequencies:
- Power the scanner OFF
- Press and hold the 2, 9, and PSE keys and power the scanner ON.
To delete a single frequency, program 0.0 into the channel - or program a new frequency into the channel (this will automatically override the old frequency).
Bill B.
Listening in since the 60's
Dec 07, 2010 | Radio Shack Pro-95 Handheld Scanner
This is not my product I have a Rca four band scanner (old) model # 16S400 need a manual for programming freq
The RCA 16S400 is not a programmable scanner. Rather, it's an old (70's) crystal-based scanner that requires one crystal for each frequency. It covers the VHF-low, VHF-high, and UHF bands, and utilizes Regency type crystals. You can do a Google or Yahoo search for the crystals, but eBay is probably the best, and lowest priced source.
Bill B.
Oct 13, 2010 | Radio Shack Pro-96 Scanner
I have an Old Regency Toutch K 100 20 CH S1&S2 S1 is 1-10 CH ?? S2 Ch 11-20 is that correct?? or do you also use CH 1- 10 on S2 ??? What is a Code '' d '' It will not scan all 20 Ch only S2, and not...
The K100 is an oldie from about 1980, when Regency was still manufacturing some radios in the USA and importing some from Japan. Below is a link to the manual for the K500, which had more channels & features than the 100, but was a similar radio. There is currently an eBay listing for the K100 manual (pdf) if you want to spend a few bucks.
Nov 21, 2009 | Radio Shack Radio Communications
Does a Regency Toutch K 100 20 channels S1&S2 Does it scan all 20 ch at the same time, S1- ch 1 S2 ch 11- 12 Etc??, what is a d code mean?
Your Regency scans (samples) the programmed frequencies at the rate of approximately 15 channels per second, so it is constantly checking for an active frequency. "D-code" code refer to any of a number of things. Do you have the term in context?
Nov 20, 2009 | Radio Shack Radio Communications
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Channel lockout on Regency D300 scanner
While in SCAN mode, enter the number of the channel you want to lockout. To re-activate it, enter the channel number again.
Oct 30, 2008 | Uniden BC72XLT Handheld Scanner
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
for scanner and old radio manuals.
from WikiAnswers
good luck
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Uniden BC72XLT Handheld Scanner Logo
390 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
