Question about Linksys Wireless-G WRT54G Router
Loosing connection frequently
I get connected to the internet, but after about an hour I have problems opening internet pages. I also get an error message saying conflict with IP address on the network. Please help me resolve issues.
Thanks
  • Anonymous Oct 11, 2008
    I have the same problem as this person...
  • Russ Andrews
    Russ Andrews May 11, 2010
    What OS? What error?
    Sergeant:
  • 352 Answers
Your computer has an IP addy and your router has its own IP addy. Try uninstalling the router and its software, reboot, and reinstall everything, this may clear up the conflict. If not you will have to go into the router(via the internet) and reconfigure the router.
anaanymous
Posted on Oct 11, 2008
I cannot open my internet it says i need to reinstall WRusr.dll before i can open it how do i get it back without the internet?
Check you antivirus and firewall settings make sure internet is allowed.
Internet connection and network errors can be frustrating and confusing to a casual computer user.
However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues.
This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems."
A window will appear, displaying the start page of the diagnostics tool.
Follow the instructions to determine the cause of the connection error.
The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing.
Close all programs and restart the computer.
If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have if don't need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an internet connection
May 09, 2013 | Computers & Internet
Tip
Frequent disconnection when using the Belkin Routers
Question:If your router loose the Internet Connection Frequently,Please follow these steps
Step 1: Connect the Modem----->Router------->Computer(Desktop or Laptop)
Step 2: Check whether you are able to see the Wired light in the Router
Step 3: Now Check the Model Number and the Version Number of your Router.
Note: You Can find the Version and the Model Number of the Routers at the underneath of the Device,it Starts with "F5D"
Step 4: Open an Internet Explorer and type www.belkin.com/support
Step 5: Download the Firmware from the above website for the model and the version number given in your Router
Step 6: Open an Internet Explorer and type 192.168.2.1 and click GO
Step 7: Now you will be able to see the belkin router setup page
Step 8: On your Left hand side click on Update Firmware
Step 9: Now it will ask for password,leave it blank and click on Submit
Step 10: Click on Browse and select the file which you download and click on Update
Step 11: The Firmware will start update in the Router ,please dont disconnect the power cable until the process gets completed
Step 12; After you have done this now you check the internet connectivity you wont be having any issue
Regards,
Aysaam
on Apr 13, 2010 | Computers & Internet
Frequent Disconnection From Internet
disconnecting from internet is a bad configuration of the Modem Router.Also bad signal from your internet provider.check all wiring,and telefone line that holds the ADSL signal.rusted telephone line connections do that trouble.
Apr 24, 2012 | APC Computers & Internet
Hi,, i hav problem regarding accessing youtube this site was not responding.. when i try to open this site there is a error opening in page,, it wont open so watz the reason behind these, can u assist me...
may be ur internet connection is a slow html connection. youtube requires good internet speed for bufferin videos. otherwise go in network connections and repair ur connection.
Sep 01, 2010 | YouTube Videos
When I open Yahoo as my homepage it opens all
Your internet connection is experiencing problems: the page data loads first, then the formatting and metadata.Basically, your browser is timing out before the formatting info has loaded. When you hit refresh, your browser tries again, and it usually will work the second time. Just an internet connection issue, nothing wrong with your computer or the website.
It happens more frequently on busy and/or slow internet connections.
Mar 04, 2010 | Computers & Internet
Frequent disconnection using wireless router
if you live in a heavily populated area you might be experiencing interference try switching the wireless channel on the routers config page. if there's a choice for auto-channel try that.
Jun 28, 2017 | Trendware TEW-432BRP Router (S4432514)
SearchSource=10&ctid=CT2269050 Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. wat to do????
Webpage display issues: "This webpage is not available" (Network errors 2, 102, 104, and 105) Issue This message displays when Google Chrome is unable to find and load the requested web page.
Solutions Check your web address and Internet connection Double-check the URL in the address bar to make sure you're going to the right web address. If you've confirmed that you're going to the right web address, check whether you can open the same web page in another browser, such as Internet Explorer or Firefox. If you can't see the web page in any browser, the web page may be temporarily down. You should also make sure you're properly connected to the Internet.
Check the error you're receiving If you can load the web page using another browser, but not Google Chrome, check the exact error you're getting by clicking the More information on this error link on the page. The rest of the solutions listed in this article are relevant if you're experiencing any of the following errors:
  • Error 2 (net::ERR_FAILED): Unknown error
  • Error 104 (net::ERR_CONNECTION_FAILED)
  • Error 105 (net::ERR_NAME_NOT_RESOLVED)
  • Error 102 (net::ERR_CONNECTION_REFUSED):
  • Unknown error
To disable the proxy run this from the command line or modify your shortcut to run chrome:
"C:\Documents and Settings\YOUR USER NAME\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --proxy-server
See here: http://tiny.cc/A2tST
Encountering this problem following your first restart after installing Privoxy (which requires changing G-Chrome's proxy settings).
If, after installing Privoxy, you elected not to have it load on system startup, manually re-loaded Privoxy. Simply reconfigure Privoxy to load on startup and the problem should be corrected.
Click on the following links for more assistance:
Check for malware
We've found that malware is frequently the culprit on your computer that's preventing Google Chrome from connecting to a web server. Use free software available through Google Pack to detect and remove malware from your computer. Learn more about removing malware from your computer.
Clear your cookies
Cookies are files created by websites you've visited to store browsing information, such as your preferences for the website or profile information. A corrupted cookie file may be causing this error to show up. Follow these steps to clear your cookies (for Windows):
  1. Click the Tools chrome_toolsmenu.gif menu.
  2. Click the Under the Hood tab and find the "Privacy" section.
  3. In the "Cookie settings" section, click Show cookies.
  4. Click Remove all.
  5. Click Close.
Make sure Google Chrome is allowed in your antivirus and firewall settings
Each program works differently, so check your software's help resources for further instructions.
Adjust your proxy settings
Feb 02, 2010 | Google Chrome
Packet data connection failed
ensure ur GRPS settigns are refreshed frequently to over come this problem
Jul 16, 2009 | Nokia 6300 Cellular Phone
My laptop is frequently having trouble detecting a connection to the internet
some of these websites limit the time port is open.. payment gateway will sometime cut the connection to protect the customer from potential identity theft... in a way this is good.. but it is frustrating for dial-up customers.
Jun 02, 2008 | Mirus (SITL51C410) Notebook
Internet search problems
If you installed a Mcafee internet security on your computer, you may need to set it up. the antivirus you mentioned can block inbound and outbound traffic maybe that is the reason why you cannot open those website that you normally visit before you installed the anti virus, you can open the configuration page of the antivirus and check try to add the sites under the allow list...
here's a link that can guide you how..
http://www.imintouch.net/pdf/McAfee_2007.pdf
May 07, 2008 | 2wire 1800HG Router (RG1800HG00)
Linksys Wireless-G WRT54G Router Logo
111 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
