Question about Umax Astra 3400 Flatbed Scanner
Toshiba Video cassette recorder W522CG
Does anyone know how to adjust the tracking manually? My tapes jump all over the place and I sometimes it rolls. I can't find anything in the manual as how to do this. I bought a video cleaner but that doesn't work
    Problem Solver:
Problem solved.--I gave it to my kids.
Thanks anyway, I appreciate you quick response
Posted on Oct 12, 2008
When playing a vhs tape the pics jump half way through watching. trying to record these old family tapes to dvd. is there a type of vcr i can buy to manually fix tracking or is there another way to solve...
There are two reasons that might cause loss of tracking halfway into a video tape. The first means you can't really do a lot about it. To check it is this is simple. When you get to the point the video jumps, stop the VCR and eject the tape. The look at the tape itself by lifting the flap at the front (push the small catch on the right side). Examine the section of the tape. If you see any damage to the tape (it should look smooth and shine) then it will never track properly.
Another cause of the jumping is caused by the take up reel, getting sluggish. Sometimes these are run off a belt, that becomes slack, replacing it could solve the problem, or it could be something else in the mechanism that's causing it.
There is another solution, particularly if the tape wasn't recorded on the machine that is playing it back. I haved used loads of different VCR's and I found that the tracking has never been set up right on any! This means that only the VCR it was recorded on generally gives the most correct playback.
Having said that it is possible to get a VCR with really good tracking. I have found that Panansonic VCR's have the best tracking. I currently have a NV-HS900 which can track just about everything, but you will only get one seconed-hand now.
Apr 07, 2010 | Televison & Video
Toshiba DVD video recorder/video cassette recorder. The picture is unstable and jumps up and down on cassette playback in SLP mode.Adjusting the tracking does not make a difference.
need to adjust the arms that hold the tape around the main cylinder use a small screwdriver and adjust each one slightly until stable
Jan 04, 2010 | Toshiba Televison & Video
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
PICTURE JUMPING
Check ALL filter capacitors, /when u find it, change also the filter resistor
Sep 10, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
Umax Astra 3400 Flatbed Scanner Logo
170 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
