Question about Whirlpool Washing Machines
Cleaning the outside of washer Drum
Whirlpool Duet Washer has mildew and dirt in sealing gasket and on outside of the stainless drum. How best to clean the outside of the drum?
Thanks...
    Sergeant:
  • 409 Answers
this is quite common for all front loading washers. the best way to clean is to use either Affresh or Washerfresh tables. you can purchase them at any appliance parts supplier.
Posted on Oct 11, 2008
Was cleaning rubber gasket for mold and noticed when I cleaned inside outer lip of steel drum a lot of brown sludge-is this grease for drum or is this build-up of some sort that should be cleaned? Also-do...
The brown sludge you are finding should NOT be grease as the bearings for the drum are sealed. This may be soap scum build up, and a combination of mold or mildew if you have been leaving the door shut between washes. It is strongly recommended by the manufacturer that you leave the door open when not in use to allow the drum air out. This aids in preventing mold, mildew and odors. The following link explains some of the common causes of front loader odors and how to remedy the problem:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
As far as the water fill hoses are concerned, the hoses are usually good for about 5-10 years (rubber), 10-15 years (stainless steel). They usually only require replacement if the rubber begins to crack or dry rot and/or begin leaking. A general inspection of the entire length of hose, cleaning the sediment screens in the ends of the hoses (if equipped) and replacing the gasket at the fitting will extend the life of the hoses. Replacing the hose has nothing to do with preventing odors. Odors are generally caused by not leaving the tub open to air out, using too much (or improper) detergent which causes soap scum build up, or a clogged drain trap. The following link explains how to access and clean out the drain trap:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a washer similar to yours and have never had any problems with mold, mildew, or odors, by following this regiment. If you have any questions or concerns, please post back and let me know. I hope you find this information helpful.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Gasket leaks water down front of machine when in use. Can it be replaced by owner?
It can be relpaced by the owner but it is alot of work. The washer drum needs to be taken out of the machine because of the spring that holds the seal to the drum assembly. Then the washer is reassembled and the seal needs to be reglued to the door area of the machine. Hope this helps.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew
I have found nappy soaker on a damp rag effective in removing mould from fridge seals. It might also work on you washer.
Mark
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frotnt door seal ghw9150
why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
