Question about NetGear WGR614 Router
Unable to connect to network
I have a Toshiba laptop and unable to connect to internet.A message " Connected with limited access" comes up
  • lynn9888 Oct 14, 2008
    I cannot connect to the internet. I called Comcast and bypassed the Router and I can get online. When I connect to the router I cannot get online. Why? Everything was working yesterday..my router was purchased in 2005. Do I need a new one<
    Novelist:
  • 173 Answers
CLICK HERE to fix
Posted on Oct 22, 2008
The internet works just fine on the laptop, but when I try to get on with my laptop. Apparently I am connected to the network, but I can't get internet access.
I believe you have limited connectivity, just right click on the network connections icon on your system tray and the select repair so that you will get a new ip address.
Hope this helps
Thanks
Dennis
Nov 03, 2011 | D-Link DIR-615 Wireless Router
Cant get my new laptop to connect to wireless - comes up with limited or no connectivity message. good signal strenght and laptop connects to other networks (eg at work) am worried that I have messed about...
Ok, the problem is that you can't connect to YOUR network right? Here's some things that could help you out:
  1. Make sure you reset your modem, simply unplug it for a few seconds. Then connect it again, select your network automatically.
  2. Make sure your internet provider's servers aren't down.
  3. Make sure modem is connected to your router properly.
Hope this helped. Good Luck!
Jan 03, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
Unidentified network which has limited connectivity
You're network card may be disabled, and that would be why you are unable to connect to yout network/the internet through your network card, to check this go to your network settings, right click on the "Local Area Connection" and if the option is there to "enable" then click it because your card has been disabled, if disable is there in stead then I'm stumped. with regards to "unidentified network" This usually comes up when someone has a wireless network created, but they have the settings made to not broadcast (show) the SSID (name) of the network. This is done for extra security, because in order for someone to connect to the wireless signal they need to know the type of encryption used, the key or passphrase for the encryption and on top of that the network name. Limited connectivity means that you are "connected" only in the sense that you can see the network connection, but you are unable to do anything with it.
Oct 14, 2009 | Linksys WRT160N Wireless Router
Limited or no connectivity
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
I have DI 524 d-link. Internet works on desktop and one laptop. Just got a new laptop and everytime I try to connect on the network of 1st. laptop, it says connected with limited access. unable to have...
Make sure that every setting in the new laptop matches the settings in the router. If one setting is off, you will not get a connection. It is also possible that the router is set to only allow specific computers to connect to it. If that is the case you will have to add the new laptop to the allowed connections in the wireless settings of the router.
Aug 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Limited or no connectivity on a laptop
you check your router configuration
your wireless configuration
number o hosts limited
Feb 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Router installation
THis can be a problem with the wireless settings of your router, I believe your laptop is trying to connect wirelessly to your router, This can be solve by accessing the router setup page and do some changes on its wireless settings settings like the SSID and the most important one the wireless security..If you're not familiar on how to do that I will advcie you to call LInksys tech support so one of their tech can walk your through with that process, they are open 24/7 this is the number 800-3267114.......
Hope that helps.........
Sep 16, 2008 | Linksys Wireless-N WRT150N Router
Not able to connect to internet
1. try to check the status of the connection:
make sure it is connected and the status does not say either of the ff:
a. local only
b. limited or no connectivity
c. limited access only
2. try to change the network name [ssid] and the network key [wep or wpa passphrase]
you can change this by accessing the ipaddress of the router or its user interface
3.try to reconnect to the new network name
and make sure the status says connected.
this is not a browser issue . it is with the connection set up.
Aug 05, 2008 | Microsoft Broadband Networking MN-500...
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
NetGear WGR614 Router Logo
93 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
