Not sure if i got dsl-924 set up right it keeps loosing internet connection
    Problem Solver:
  • 28 Answers
If ur internet connection is unconnected in between intervals of some 5 to 10 minutes, then it may be problem of ur MODEM or LAN card. The cable may be loose or the device may be faulty.The DSL link setup is perfectly OK. try changing ur MODEM/LAN card with other one.
Posted on Oct 11, 2008
My acer 5315-2153 keeps asking for an isp
it shouldn't be asking for an ISP as most dsl modems even though they are PPPOE by nature, DSL providers have removed the necessity to add all the information to the configuration. I recommend removing all connections already present in the machine, not the adapters or anything physical just remove all known connections. don't run any kind of internet set up wizard because you don't need it. just connect the device to the router/modem. if you connect directly to the modem you'll need to reset it after connecting the new machine. If internet explorer/firefox/chrome are being used make sure you double check proxy settings and turn them off. this is listed under tools in the browsers. I would also make sure both the wireless and wired connections have been set up to 'automatically receive an IP (dhcp) and that no info has been pre-added to the configuration. set everything to be automatic and reset your modem and you should be good to go.
Apr 04, 2012 | Acer Aspire 5315 Notebook
Phone Number 847-699-9958 New DSL Internet problem getting it installed on my computer. Error message is, Your computer is not connected to the 3 Wire Gateway. e-mail address is...
You need to connect your computer to the dsl box and the box to the wall as instructed, you may have to change your internet settings a little.
Find the my network places icon on your desktop, right click and select properties
the network connections screen comes up, you can also go to this via the control panel
right click your internet connection select properties
scroll down the list to internet protocol tcp/ ip select it and press on properties
make sure the settings are set to Obrain an ip address automatically and the 2nd page is empty,
click ok
click ok again
try your internet again.
Aug 11, 2008 | Washing Machines
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
Hi,my zxdsl 831 recently the 'DSL' LED keeps on offing by itself from time to time,whereelse my 'PWR' and 'LAN' Led still works normally(resulting unable to connect)...ive read the book manual but isnt...
if the LED goes off and on but your internet access is fine then the LED is buring out. (very rare)
BUT if your internet comes and goes with the led light then you need to contact your dsl provider and find out why.
FIRST you should check your phone line cable to make sure it doesnt have a break or loose connection somewhere.
Mar 09, 2010 | Computers & Internet
I have DSL/verizon,modem 6100F i keep loosing my internet connection
modem did not correct for set up and help to set correct also sorensen router need to set up for modem thank
May 27, 2009 | Westell Wirespeed LiteLine 6100...
Browser problems i need to re-install my internet explorer
wel check and make sure all your settings are correct fist go into internet options and make sure proxy isnt checked and you dont have it as trying to connect through something other than your dsl
Feb 12, 2009 | E-Machines T1100 PC Desktop
I have an AT&T Modem; having trouble with internet connectivity
It is OK to keep putting the UN and PW in. However you shouldn't have to. I suggest having a tech come to your home and have them do a signal test both at your jack and outside with your home unplugged from your service box. If there is a big difference in the numbers then you're simply loosing signal due to signal bleed inside. This is a simple fix. Have them isolate some wires in your jack and place a DSL filter outside. Then your DSL signal will go straight to your modem and not bounce all over your home. This will NOT affect your phone.
Dec 31, 2008 | AT&T High Speed DSL Modem
My linksys BEFSR ver.3.1 S/N C2140DA22073, constantly drops my internet cinnection after a few minutes of none activity.
Do you use DSL for your connection?
DSL uses a phone line for the connection, and therefore if your ISP doesn't detect activity after a few minutes, it will drop the line. There is a setting called "keep alive" in your router which will automatically either redial or 'ping' your ISP to make sure this doesn't happen. It's in the basic setup screen; if you're using DSL enable it and set it to 1 minute.
May 28, 2008 | Computers & Internet
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Can't connect to internet using DSL
Open My computer, then My network places. Then open View network connections. Your connection should say "Local area connection". Right click it and make sure it's set to "Enabled". Then Right click it then select repair.
Nov 08, 2007 | Toshiba Satellite 1805-S253 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
