Currently all 5 of my dryers are set at 99 minutes runtime. I'd like to reduce it to 45 minutes.
SOURCE: I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: [email protected].
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF” flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02” flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
SOURCE: Timmer Maytag Commercial Dryer
the maytag timer for MDE10 should be a multi vertical slide in type. If so under the keyed panel on the top of the dryer, is an electric control with a grey knurled knob facing the front of the machine.
This grey knurled knob is the time set.
The knob rotates clockwise (from front) under motor control while the dryer is running, and jumps back to starting position under spring control when the slide is pushed in.
There is a single grey stud moulded into the front of the knob, that is the sixty minute mark, and a number of slots before the stud, that take a nylon peg. they are 6 minutes apart 54 48 42 36 30 minutes. Inserting a nylon peg in the slot at 30 minute will do what you want.
Most service guys drop the peg in the bottom of the control when they remove it, makes it easier to find, next time, so if there is not a peg in any slot, examine the floor if the enclosure, A short nut n bolt will accomplish the same result if the peg is not there.
If the original multicoin push in has been replaced with a newer single slot device I dont know how the change is made, none of my dryers are that new.
SOURCE: Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
