Question about Avanti BCA5102 Stainless Steel Compact Refrigerator
Whines/ Whistles when running
This is a new unit that whines/ whistles when it is running. It's coming from the back of the unit where the motor and compressor etc. are.
Help!
Loud hum or whine coming from intake maifold
Check for cracks or air leaks. These can cause hum/whine/whistles. Spay soapy water solution on the manifold at joints. Avoid spraying anything electronic directly. If the noise suddenly stops, you have found the air leak.
Sep 28, 2015 | Cars & Trucks
99 f150 whines unless ya put on the gas
Sometimes the IAC valve can cause a whistle sometimes resembling an airhorn. Does the truck have a rough idle? With it having an emission leak code i would assume that you probably have a hole in the rubber boot that goes to the PCV valve located in the passenger valve cover. There is a plastic tube that runs from the back side of intake behind the throttle body to the valve cover it will have a rubber elbow on each end of it. Look at the end behind the throttle body. It will probably resemble this.
Jan 24, 2014 | Cars & Trucks
I get a steady moaning/groaning noise from my vents.....someone told me that the baffle doors are always moving? Whats going ON???????
Try opening all the vents all the way, sometimes when one is only slightly open, the air rushes through it so fast that it whistles or whines.......had the same issue on my eclipse
Apr 04, 2011 | GMC Jimmy Cars & Trucks
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
LG HD Flat screen TV whistles
Ur power supply board is where the whistle came from.
Open the back cover,take a screw driver back handle taps all the transformers, so all the gaps pockets in the transformers clear up.The whistles will stop.
Dec 13, 2009 | LG 32LG30 32 in. LCD HDTV
Scanner stops partway along path, motor whines
There is an obstacle in the scanner path, or the scanning head guides got bent (unlikely). There could also be something in the rubber drive belt driving the scanning head gears. Try looking inside with a light and check for scratches on the guide. Unfortunately, to fix the problem you'll have to either send the scanner to maintenance, or to open it yourself (voiding the warranty).
Oct 30, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
3 speed automatic transmission changes gears to fast
Can't be certain from the description but the cut wires might well be vss (speed sensor). If so, this can cause several serious problems with your system as the vss is a major input for both engine and transmission control. The speed sensor mounts where the older models speedometer gear/cable would have been.
Jun 24, 2009 | 1993 Jeep Wrangler
Whining from engine when in gear
Just a thought- remove the oil filler cap when the whine is present - (this checks if PCV valve is faulty, causing high crankcase vacuum, which in turn causes a whistling/whine noise as air leaks past engine oil seals). Worth a check.
Try listening with a short piece of hose pipe to locate immediate area/source of noise.
Jun 17, 2009 | 1998 Dodge Ram 1500 4WD
Avanti BCA5102 Stainless Steel Compact Refrigerator Logo
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
