Speaker is off on television
How do I get the tv speaker back on?
  • Anonymous Dec 24, 2008
    i lost the remote to my tv and dont know how to turn the speakers back on
I have an older Mitsubishi, don't know the model ## but this solved my problem of "speaker off" without using a remote. First, on my tv when I would press the volume button up or down the sign "speaker off" would show up on the screen. Before this sign goes off of the screen press the "adjust button" up or down until you have the result that you want. I hope that this helps!!
Posted on Jan 06, 2009
Samsung HLP5067WX No sound from internal speakers
Check ur tv it is not on mute mode.Try go into tv menu go to Audio Seting reset every back to factory setting.Check ur tv Audio Setting is it not on VARIABLE setting.Must be on FIX setting to able to used tv internal speakers.These steps should help tv get audio back.
Aug 08, 2011 | Samsung HLP5067W Television
Sony Bravia KDL-40V3000 - sound is directed to the headphone jack and not the speakers. Cannot get it to play to the speakers.
Go into the tv menu go into the AUDIO setting,go down to do a resetting for a back to the factory setting.Now go to OPTION setting go down Output Select and enter and pick Fixed for speakers for the tv option,now tv will play on the tv speakers
May 12, 2011 | Sony BRAVIA KDL-40V3000 Television
Can my tv play sound through tv and speakers?
There should be an Output in the back of the TV. You will need to get an RCA cable which is the Yellow Red and White cables. Connect the yellow and white cable to the Output in the back of the TV and connect the other end to the Speakers.
Feb 02, 2010 | Insignia IS-LCDTV32 32 in. Television
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
NEC 42VM2A plasma tv switch to internal speakers
I don't know if you have the owner manual for this T.V. or not but if you need one you can download a manual at www.devicemanuals.com/guide/Television/ Hope this helps!
Dec 03, 2009 | NEC PlasmaSync 42MP2 42 in. Television
HOW DO I HOOK UP SPEAKERS TO MY TV
Yes, connect RCA stereo cable at TV OUT or MONITOR OUT terminals at back of TV and connect it to receiver input to get TV sound from amplifier speakers.
Mar 28, 2009 | Hitachi 57F500 57" Rear Projection...
Sony KV-32TS20 speakers
unpllug tv
remove back cover
speakers are all the way inside. under the picture tube
Jan 04, 2009 | Philips TS2744C TV
Turning on Internal TV Speakers
either your model tv ,doesnt have that option,,or its on the back,,check the rear of the tv,,good luck
Oct 01, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No volume
On the back of your set there are 2 switches that tell the tv whether you are using the internal speakers or the external speakers.
Make sure the switches are set to internal so the speakers in the TV receive the sound signals. If they're set to internal maybe the internal speakers are bad. Set the switches to external and hook up external speakers to the speaker terminals on the back of the TV. If neither setup works then it sounds like an output transistor or related parts.
Sep 01, 2008 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
368 people viewed this question
Top Televison & Video Experts
Electro Med Services...
