Question about GE Spectra JBP78 Electric Kitchen Range
Cooking element how do i replace a burned out element on my spectra range
  • 1,543 Answers
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Posted on Oct 11, 2008
Why are my rolls not cooking on the bottom but fine on the top and my element is working fine
My guess is this is an electric range. If I am right then it has 2 elements--one on top and one on the bottom. Plus you stated it has convection cooking. Sounds like the bottom element in not working right so all you are cooking with is the top element. In convection cooking the fan circulates the air for even cooking.and sometimes has its own element around the fan. Look closely at the bottom element for any burned out or melted areas that might show. Sometimes they just burn out with no outward signs.
Feb 22, 2015 | Kitchen Ranges
Heat element burnt out replaced with new, still will not heat
one of heating element burns out how can i replace it? amana brands cooking range
Apr 03, 2011 | Amana AER5515QA Electric Kitchen Range
I have a GE spectra JBP24 model. I turned on the oven and in a few minutes noticed a funny light inside. When I opened it up the element was burning. I unplugged the stove and when it cooled down, I went...
This is a common but spectacular occurrence when a bake element fails. You can go to your local appliance parts store with your model # and they may have a replacement element in stock.
Remember to rinse the baking soda out prior to using the oven.
Aug 29, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Gets warm but not hot enough to cook
most likley the bake element is out! inspect it with a flash light to see if its burnt ..to replace unplug range!!! remove oven door ..open door 3 inches pull up ouickly towards ceiling to remove from brackets ..then remove racks..their are 2 screws holding element in remove them to pull out element ..then remove wires install new bake element.. let me know if it worked ..good luck/joe/
Aug 25, 2010 | GE Spectra JBP78 Electric Kitchen Range
My lower oven element started to glow white hot so i turned it off . it continued to glow and travel about 6 inches until i pulled the plug, the element now has a break in it. is my control faulty too or...
The element can just be replaced, Sometimes these will start a small fire inside the oven. It's just the element has burned completely out. Some of these are tricky to take out, but it's fairly easy.
Apr 04, 2010 | GE Spectra JBP78 Electric Kitchen Range
My GE Spectra heating element caught on fire today and completely disintergrated. Is this common?
IT CAN BE IF THE ELEMENT HAS NOT BEEN REPLACED FOR A LONG TIME AND IT SOUNDS LIKE THE TERMOSTATS HAVE FAILD SO REPLACE ELEMENTS AND TERMOSTATS AND YOUR OVEN WILL HAVE A NEW LIFE .
Nov 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Heating element in the oven appears to burn out, can it be repla
yes but be sure to turn the breaker off or unplug the stove cause the element has power on it on one side all the time and will short out when you take it out. you should see a screw on the plate that the element is attached to in the back of the oven that is how you get it out..
Sep 27, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven not heating enough
check your round screw-in fuses. I suspect 1 is burned out. there are typically 2.
Sep 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom heating element in oven is not heating up.
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
318 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
