Question about Dell Dimension 2400 PC Desktop
Blank monitor I accidently deleted computers monitor driver. computer starts up ok and shows "windows xp loading" then goes blank!
  • conmec51 Oct 11, 2008
    once i go into safe mode the screen fills with text such as " multi(0)disk(0)partition(2)\windows\system32\drivers " then nothing elso responds. cannot logon to administrator.
  • Dell Master
  • 1,183 Answers
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Posted on Oct 11, 2008
  • Mandeep  Singh
    Mandeep Singh Oct 11, 2008
    Well, the problem is little more than the video drivers alone,when the video drivers were deleted with them some of the windows files also got deleted ,ie. is the reason you are getting this error message in safe mode.
    Do you have access to windows xp cd , that came with the system. If not call Dell technical Support , they would send it to you free of charge. If you have the cd, we need to run a repair on your computer using the cd.
    Thanks
    proton
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
My computer screen goes blank when I change the user
Hi, A(n) (recently) installed program is probably causing the problem, interfering with the service that takes care of the logon and -off process. To see if this is causing the problem, you can try the following:
Use this method if you remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': rstrui.exe 3. 'System Restore' opens 4. Select a date from which to restore your computer from. Needless to say, the date you choose should be a date on which you weren't experiencing the problem :-)
Use this method if you don't remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': msconfig 3. A system configuration window will show, where you can change the way Windows starts up 4. On the 'General' tab select the second option to boot diagnostically, loading only the standard devices and services. 5. Click 'OK' 6. Click on 'Reboot' 7. When you're computer has rebooted a message will show telling you that you've changed the way windows should start up and the system diagnostics window will show as well. 8. Since only standard devices and services have been loaded, try to logoff or change user and see what happens. If everything goes well, you know that a program, which should be a program you've installed before any problems started showing up, is causing the problem. If not, there's a corruption in the services of your operating system. 9. If everything goes well, you can start loading other services (from programs you've installed in your computer) one by one from the 'System configuration' window by clicking on the 'Services'-tab.
When you've found the the program that's causing the problem, delete it from your computer and select from the 'System configuration' window, 'General' tab the first option, for windows to start normally.
I hope this helps Good luck.
Cheryl
Jun 22, 2009 | Microsoft Windows Vista Home Premium with...
BLANK SCREEN
Check the following:
Shorted or blown capacitor(check for bulging)
faulty external power adapter(check with another)
Faulty lcd back-light(if other option fail this is it)
Jan 18, 2009 | Relisys RLT1720 17" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 2400 PC Desktop Logo
229 people viewed this question
Alun Cox
