Question about Kenmore 16.7 cu. ft. Freezerless Refrigerator
Water pooling on the bottom shelf of the freezerless refrigerator
There is water pooling on the bottom shelf of my freezerless refrigerator.
    President:
  • 1,462 Answers
Take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Posted on Oct 11, 2008
Water pooling on top shelf in refrigerator with top freezer
Your drain is obstructed within the freezer compartment causing the water to floe into to lower section via vent ducts. To correct this, you will need to access the rear wall of the freezer and at the bottom you will find the drain hole. Remove the obstruction with warm water and remove all the ice also.
Good Luck
Mar 06, 2016 | Refrigerators
Water leaking from my refrigerator
seems to be a condensation proble, is it possible to lower down fridge temperature a bit? This may solve the problem.
Mar 19, 2008 | Refrigerators
What causes water to pool on the top shelf?
Hello
It is caused by a clogged defrost drain in the freezer compartment of your refrigerator
To fix this you will need to empty your refrigerator and unplug it.
Remove the back panel of the freezer and look under the cooling coil, you will see a frozen drain
pour hot water on the drain hole until water flows freely through the drain to the bottom pan..
That's it
Jun 04, 2015 | Frigidaire FRT21H8 Top Freezer...
How to tell the model number
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Nov 23, 2013 | Liebherr KIKNV3056 Bottom Freezer...
Ice and water on the bottom shelf of my sears Kenmore regular refrigerator. things are cold but water pooling on the bottom shelf.it is a Kenmore freezer on top and refrigerator on the bottom
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Jan 18, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is pooling in the fridge from the icemaker, line is not plugged or leaking. It just seems like too much condensation from somewhere
behind the freezer wall is a drain to the bottom condensate tray under the refrigerator this is clogged remove the plastic inner wall remove the ice buildup on the coils and, coil shelf then: clear the drain with hot water poured into the drain hose with a funnel
Sep 03, 2009 | Refrigerators
Water is pooling on the bottom shelf and in the
Hi I can help you with this annoying problem.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 14, 2009 | Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerator not working properly
laurau In order to better help you I need the complete model number and the serial number of your fridge. Gendos
Jun 29, 2007 | Kenmore 16.7 cu. ft. Freezerless...
Refrigerators Logo
438 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
