Question about HP Pavilion dv1000 Notebook
Which function key allows to switch to tv
I connected to my computer to the tv via s-video cable which function key allows my to switch back and forth
  • 186 Answers
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Posted on Oct 15, 2008
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Aug 23, 2014 | Acer Aspire 5350 5750 5750g 5750z Series...
How to connect my dell latitude laptop to my symphonic tv via s-video cable
Run the S-Video cable from the laptop to the tv. Take the tv's remote control and hit the Select Input button. Select S-Video or PC as your input source. Reboot the laptop and the video might show automatically.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Dell Latitude D610 Laptop Computer -...
When i connect my laptop to the tv i get sound but no pic.
Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Feb 11, 2010 | Dell Studio 1537 Laptop
I connect my sanyo 42 inch LCD tv via s-video, no signal on TV
Be sure you changed the source on the tv (i'm guessing you did this), be sure you switch the out-put on your computer to s-video. You can do this in the properties box. If you are running the nvidia video utility, you can set up hot keys to do this. I set up ALT, Z, 3 as my hot key combination. All I do is hook up to my tv, press the three buttons above, at the same time, and the video moves from my pc monitor to the tv.
Sep 10, 2009 | Nvidia GeForce 7200 Graphic Card
VIZIO VO42LF says no signal when connect to PC after power on/off
Could be a sensitivity problem, have you tried to switch tv modes back and forth, sometimes if you do that it will save you from restarting the computer. I had a tv about 10 years ago that had a sensitivity issue, went to see about fixing it, unfortunately, the tv brand was no longer in the country and user service parts were not available.
Apr 11, 2017 | V, Inc. Vizio P4 Plasma Television
CONNECTING DTV CONVERTER AND STILL USING DVD PLAYER
Get a set of video cables to connect the DVD player to the TV.
Then follow the numbered instructions in this post to connect the DVD player, and use your TV remote to switch the video mode when you want to watch a DVD, then switch it back when you want to view TV.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 24, 2009 | Toshiba 32AF42 32" TV
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Display my laptop on my tv
You can't connect a standard TV to a computer using a VGA cable. If you have it, use the composite (yellow) RCA jack or S-Video from your laptop. As for turning off a laptop monitor, look on the function keys for LCD/CRT or icon for monitor (typically 3, 5, 7, or 8) hold down FN key and press the correct function key.
Jan 13, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Dvd
Using an S-Video Cable.......
or
if your video card has tv out... then use the connector and RCA cables
then press the FUNCTION key and F5 together to toggle back and forth from TV to PC
Jun 09, 2008 | Gateway MX6920 Notebook
HP Pavilion dv1000 Notebook Logo
4,731 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
