Question about Gaggia Titanium Espresso Machine
No coffee is dispenced
My mothers Gaggia Titanium acts as if it is going to dispence coffee.
It goes through the process, then does not produce any coffee. We have tried to rise and clean the machine, we get hot water and steam from the
tube for latte's but no espressos or cups of coffee
  • Anonymous Mar 27, 2014
    coffee doesn't come out properly.
  • 3 Answers
Ok, If you pull out the waste water tray and bean tray, along with the brew unit ( by pushing the lever that says push) turn the brew unit upside down and you will see a layer of waste coffee grinds on a circular metal plate, just rinse it under a cold tap, dry it off and reassemble
Also you may want to try rinsing other parts of the brew unit and give it a general clean if there are any other build-ups of coffee grinds :)
Posted on May 16, 2009
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
Gaggia Titanium machine computer control malfunctioning
AN EXPENSIVE ELECRONIC MACHINE LIKE THIS ONE IS REQUIRED TO BE PLUGGED IN INTO A DEDICATED OUTLET WITH ITS OWN CIRCUIT. BROWN-OUTS, SPIKES, UNDER-VOLTAGES COMMONLY PRESENT IN ANY HOUSE WOULD CERTAINLY AFFECT THE MACHINE SENSITIVE POWER SUPPPLY AND ONCE IT FAILS THEN THE MOTHER BOARD , TOO.
Sep 05, 2014 | Gaggia Titanium Espresso Machine
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
Water dripping not running when making coffee
First question:Are the rest of the machine still working correctly?
Second question:How was the waterflow before descalling?
Here are short description on how most of these machines work.
It will have a cold water reservoir for filling with cold water with some sort of water full sensor, it will then be followed with a high pressure pump.which are used to fill the boiler.After the boiler it will then go out to your to disspencers.in your case the steamer and one for coffee.The outlet at the boiler will propably be split in two by using valves.
To come back to your problem i assume it had a waterflow probleme before you descalled.When you are descaling your machine their are some times pieces of scale that is not propably disolved by the descaling process which will get stuck in the pipe work acting as a valve
causing waterflow problemes.
The other probleme might be that your water dispencers valve might be faulty either by a poor supply(power) or the sollenoid is starting to size up.
Just switch of the machine when taking of any covers you are working with water and electricity which do not mix well
Mar 26, 2012 | Gaggia Baby Espresso Machine
Gaggia titanium not heating up.
It is easy to replace the thermostat and your diagnosis is correct. There might be a resettable thermostat on the boiler.
Jun 22, 2010 | Gaggia Titanium Espresso Machine
Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
Jan 24, 2010 | Gaggia Syncrony Espresso Machine
Gaggia Titanium - Cold coffee although producing steam.
The only thing that comes to mind is one of the thermostats on the boiler.
Jul 19, 2009 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
361 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
