Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
The ice melted and now the whole fridge does not get cold.
The fan is still working but the fridge is not cooling at all. I cleaned the back panel and got all the dust off of it is there anything I can do to fix this problem?
  • rene25 Nov 05, 2008
    The ice melted and now the whole fridge does not get cold. problem, and notify you when a new solution is offered.
  • cowlick428 Dec 06, 2008
    fan is running...compressor is not running but is getting hot.
My Fridge get frost on the back of the the bottom of the freezer and wont get cold
Posted on Oct 11, 2008
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Why freezer not working...ice is melting
Can you hear the fan running in the freezer when you have to freezer door open? If not the fan that blows the cold air over the cooling coils is either broken, or the fan is frozen in ice. We had this happen to us. We thought the fridge was dead. removed panel in the freezer compartment (in the back) and exposed the fan. Changed the fan, works good. good luck
Apr 19, 2013 | Refrigerators
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Not cooling
Cooling fan, behind internal plasic panel is frozen up, happens with me regularly, self defrost function not working properly, i'm just fixing mine as I write. I have found that bottom drain hole was all full of ice also. Have cleared with anti-freeze/hot water till runs through. Take out all shelves, remove back panel, there are screws behind chrome bezel and also inde-odoriser recesses (those two square plastic covers). Unscrew plastic water chiller, be careful not to damage pipes. Remove the back platic moulding, unclipping wire connectors and cooling fan is fastened to back, it will be frozen up with ice! I use hair dryer/ de-icer to thaw, dry off as much as possible. Beware, moulding is mainly polystyrene, i.e fragile. I suspect that I keep getting problems because I didn't clear out the bottom drain hole, so it did not defrost. Tell tale sign is noisy fan (hitting ice) which eventually freezes up and stops blowing cold air which causes fridge to stop cooling, compressor still works though!
Jul 23, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge is not cool. Freezer has soft ice buildup inside
Your website is fantastic... it really helped me and saved me money!!!
I defrosted my fridge overnight. Cleaned all the water up. Plugged the fridge back in and it works likes new. Thanks :):):):)
Mar 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
