Question about Pace Type 30-0060 1121-0369 D1 .060 D2 .188
Fresh Water Supply
Where is the drain for the fresh water supply in my 1977 Pace Arrow RV?
Thanks.
Mark
annie74@csicable.net
Mark that is an easy answer on my 77 pace arrow if you look on the driver side of the motorhome underneath there is a vale down there so that you can drain and blow the lines for the winter. I found out the hard way about mine the first time that i turned on the water and it poured all over the ground. Maybe you can help me where is your lp tank on yours i can't find it on mine any ideas
Posted on Mar 21, 2009
I want to drain my fresh water tank.I winterized it so now want to drain and sanitize.
This drain is going to be located on the underside of the RV close to where your fresh water tank is. It will probably even be labeled but you will have to get on the ground and take a look for it.
Jul 04, 2016 | RVs
Where does the white wire? go on fresh water tank level indicator for a 1986 pace arrow by Fleetwood
SORRY we would have n idea . but check what works and doesn't then you might have located the problem .
Feb 28, 2016 | Cars & Trucks
Where is the drain for the water tank on a 2001 Dutchmen 26 ft. travel trailer?
I assume you mean the fresh water tank. These drains can be just about anywhere, but always at a low point.
If you can't contact the dealer or manufacturer for location, look underneath the RV, under the sink, behind removable panels inside, and close to the waterpump either underneath it or in the waterpump compartment itself.
There are usually 3, freshwater tank drain, cold water line and hot water line. Some turn and some pull up. Experiment which is which or try to trace them back to origin.
Oct 01, 2014 | RVs
How do you get mold out of fresh tanks?
There should be a fresh water fill on the outside of the coach. If not then there is a valve that would need to be turned that will allow water to be put into the fresh water tank. If that is the case then it will be a bit more difficult to put bleach into the fresh water tank but not impossible. There will be a pump that draws fresh water out of the tank. You can disconnect the input and output lines. Connect the input line which comes from the fresh water tank to the output side of the pump. Then using a flexible line with a 1/2" pipe thread fitting, connect that to the input side of the pump. Put the loose end of the flexible line into a gallon of bleach and turn the pump on. It will draw the bleach out of the container and pump it into the fresh water holding tank. Now return the plumbing of the pump back to the original configuration. Using the valve system complete filling the fresh water tank with fresh water and allow to sit for a couple of days. Then open the low point drain on the fresh water tank and completely drain. When the coach is not in use make sure the tank is completely drained. There is also a fresh water treatment that you can purchase at your local rv parts department.
Jun 13, 2014 | KZ Coyote Rock Climber CRC220 RVs
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
Where is fresh water intake valve on jayco 2005 motorhome
Normally would be a door outside to open and you'll see "Potable Water", as well as a city water hook-up where you can run direct from Garden type hose to supply at tap.
Dec 20, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Electronics - Others Logo
266 people viewed this question
Top Pace Electronics - Others Experts
Are you a Pace Electronics - Other Expert? Answer questions, earn points and help others
