Question about Dacor Preference RSD30 Gas Kitchen Range
Clock is in Military time...can't change it back...
We have had a Dacor RSD 30 for 5 years...our clock suddenly displays in Military time. We have turned the breaker off...tried to set again. It reverts back. Also....the manual says it will display am or pm when setting...it doesn't.
HELP....thanks
  • Anonymous Feb 20, 2009
    our clock is also stuck on military time, no idea how it even got set to military time. searching the web for an answer...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
Posted on May 04, 2009
  • dulie2k Jan 30, 2011
    There have been some occurrences where the Time readout has been in a 24 hour
    Military Time Format. In addition, there are also instances where the clock is set for a 50
    HZ operational mode causing the readout to gain time.
    If either of these situations occur please perform the following to reset the ERC for proper
    operation:
    Two persons are required the reset function. The first person should be at the power panel
    (circuit breaker box) and the second person should be at the oven.
    1. Turn the circuit breaker for the oven.
    2. While the power is off, the person at the oven should press and hold the "Clock "
    button.
    3. The circuit breaker should then be turned on while the "Clock" button is still depressed.
    Continue to hold the "Clock" button until a single digit number appears. You may then
    release the button.
    4. Using the "Time-Temp" arrow keys, adjust the number in the display to read the digit
    "8", and release button.
    5. After approximately 15 seconds, the time of day will appear.
    6. Set the clock to the correct time of day by following the instructions in the owner's
    manual.
    The oven will now function properly.
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
I just purschased an Lg 26LV2500 and I can't get the military time off the screen when it is first turned on. I've set the clock manually with the month, date, and year and I've set the hour...
When you click on the clock icon the clock setting menu comes up scroll down to the bottom of the list if it is available it is two lines below the options on screen and change it to am\pm press return go back up the list and click option to set clock set clock press back /return then exit
May 14, 2017 | LG Televison & Video
How do i change from military time on a insta-set alarm model 40009?
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
Mar 16, 2009 | Equity Time USA Insta-Set 44200 Clock...
Clock is stuck in military time & I can not get it to go back
The newer Dacor ER36D can by switched from standard 12 hour to 24 hour military time mode and back by holding the CLOCK SET button for 6 seconds. That may work on older models as well.
Feb 28, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Military Time
Press the "function" button for a couple of seconds. The display will indicate 12hrs or 24hrs.
Use the minute or hour to change the setting for 12hrs and you'll have normal time again.
I hope this helps!
Feb 02, 2009 | Digital Products International Clok Smooth...
Rsd 30
I believe I followed the post by Rotu on11/11/06--remove the black grill surrounding the oven door latch (it's held on by 4 black phillips-head screws about 3" on either side of the latch). I had to use a flashlight to see into the space (there are a bunch of wires as I recall). In the middle several inches back you will see a small (about 3/8") red (mine had darkened) button. We used a screwdriver (be sure your circuit breaker is OFF) to reach it and push it down to reset. Replace the grill, turn on the breaker and you are good to go.
Dec 20, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Getting the clock off military time
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
Sep 17, 2017 | Audio Players & Recorders
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
Dacor Preference RSD30 Gas Kitchen Range Logo
1,063 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
