Question about Bosch 14.4V Brute Tough Drill with Blue Core Battery Technology
Bosch drill 14.4 volts
Drill Approx. 2 Yrs. old. It vibrates at high speed. when it stops , it Makes a clicking noise louder than before.
  • 154 Answers
A fresh set of carbon brushes will solve this problem. P/N 2607034900 Go to a Bosch service center and they should have them
Posted on Apr 13, 2009
My Bosch 24v PSB 24 VE-2 has suddenly stopped working. The battery charges ok but when fitted into the drill , the drill makes a faint whining noise but fails to work. Any ideas ?
Hello
The motor windings in the drill are bad or have a bad connection.You may also try cleaning the battery contact points with a pencil eraser.
Jun 25, 2011 | Bosch Drills
How to repairreplace brushes for 36 volt bosch lion batt drill
There are black access panels on each side if the drill toward the rear. Remove the screw that holds them in, and remove the panel. This will expose the bruch holder, take a small screw driver and carefully remove the old brushes and replace them. Replace the panels.
Jan 24, 2010 | Bosch 36V Litheon Drill/Driver With 2...
Dewalt 18 volt drill with gears slipping
Check the speed selector switch on top of the drill... it can get dirty and not fully engage. Cycle the swatch a few times back and forth and stop in your desired indent (1, 2, 3) when you feel a real positive click.
Dec 30, 2009 | Dewalt 18 Volt Compact Drill Kit
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't...
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Oct 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
Dewalt drill binding
If you noticed this sound the first time you tried the drill, it is noise of the armature brake.  This noise is normal and not a problem at all.  Michael Mittelsdorf
Dec 27, 2008 | Dewalt DC988ka 18 - volt XRP 1/2''...
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Bosch 14.4V Brute Tough Drill with Blue Core Battery Technology Logo
184 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
