Question about Apple iPod classic MP3 Player
Click wheel When I turn my ipod on, sometimes when I rub my finger over the click wheel it doesn't move the highleted section on my ipod. When I try a little longer it begins to work. Is this normal?
  • 31 Answers
Hey :), id be happy to help. This problem has happened to my Ipod too. And yes, Im pretty sure it is normal. But Id recommend for you so soft reset your Ipod ( this will not remove any of your music or etc. of your Ipod). To do this just hold down the menu button and the center button at the same for 10 seconds , until the screen goes black and the apple logo shows up, then in a few seconds it will go back to your ipod's menu. Also make sure you have the latest updates for your Ipod, because these updates get rid of bugs/glitches on your Ipod. Thanks! and I hope this helps.
Posted on Oct 11, 2008
Only turn on de logo apple no more
Hi, NOTE: First make sure that your iPod's hold button isn't on. This is the little switch at the top left corner of the click wheel iPod that you can move to "lock" the iPod's buttons. If this is on, you'll see a little orange area at the top of the click wheel iPod and a lock icon on the iPod's screen. If you see either of these, move the switch back and see if this fixes the problem.
If the hold switch wasn't the problem do the following:
Move the hold switch to the on position and then move it back to off.
Hold down the Menu button on the click wheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod video. You'll know the iPod is restarting when the screen changes and the Apple logo appears.
If this doesn't work at first, you should repeat the steps.
If this doesn't work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
If this doesn't work, you may have a bigger problem, and ought to get more help.
apple.com/support/ipod/
Feb 23, 2011 | Apple iPod touch
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Click wheel
This is perfectly normal.
I have the same problem with mine.
It is because the new ipods are less sensitive.
Simply press menu then reenter the section. The click heel should be easier to use.
Oct 03, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod 5.5 gen video wont sync with itunes on my laptop and only sometimes charges. can anybody help please. its be a present for my ma (mother) for christmas
  • iPod classic
  • iPod nano
  • iPod mini
Dec 07, 2007 | Apple iPod MA446LL/A MP3 Player
Apple Ipod Video
  • iPod classic
  • iPod nano
  • iPod mini
Nov 29, 2007 | Apple iPod MA446LL/A MP3 Player
Usb problems with 2nd generation ipod
Aug 21, 2007 | Apple iPod nano
Frozen ipod
Aug 02, 2007 | Apple iPod nano
Apple iPod classic MP3 Player Logo
35 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
