Question about Mustek PVR-H140 Digital Media Player
Pvr it hit the floor now does not go to main sreen
Hello.
Try to remove the hard disk and check it with CHKDSK on your windows system with a USB rack.
If there is a problem, format it with this http://fat32.storex.eu/ and restore the files(mustek.de).
Then it will work again.
If your hard disk is correct, then you need to check the electronic device, connection, battery, and so on... Otherwise a check of your device has to be performed by an expert in electonic.
good luck!
Posted on Nov 23, 2008
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
Why won't my PVR record anything or let me access files?
Hard disk corruption is the most likely cause. This can be caused by many things, such as: failing capacitors, poor signal, switching off at the mains while recording.
What is the make and model of the PVR?
Mar 14, 2014 | Televison & Video
Humax displays 'synapse' when trying to view video. sound is ok
I had this problem, perhaps after pressing some keys on the remote control wrongly.
I turned off the TV at the mains. I turned off the PVR at the mains.
I turned both the TV and the PVR back on, and both worked correctly.
Jan 08, 2014 | Humax Dtr-T1000 Youview Digital Tv...
1994 Cadillac AC Blows through Main Vents hit a bump and it blows through defrosters, hit another bump, and it blows back through the main outlets>
Sounds like a faulty blend door actuator. This part diverts air from the different ports ie floor, vents, defrost. If it keeps changing when you hit a bump, either the actuator has a loose connection or it's bad all together.
Jun 09, 2011 | Cadillac DeVille Cars & Trucks
I need a driver for kworld tv tuner pvr 305u.... and my os is windows 7... how can i install the driver?..
You can download driver on this page
http://global.kworld-global.com/main/support_down.aspx?mnuid=1255&modid=14
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 03, 2011 | Computers & Internet
After purchasing a PVR machine from Shaw cable, our Samsung series 6 51" LCD tv requires having the source output on HDMI3. Is there a way to change the " TV " button on the remote to...
We had this same problem on our Samsung 5 series. What we ended up doing was leaving the PVR plugged into HDMI 3 and renamed HDMI 3 to PVR. If you go to your source list and hit the Tools button (i believe its Tools) you should get the option to rename or give a nickname to a particular source.
Jan 10, 2011 | Televison & Video
Need a code for an Atlas PVR universal remote control on a 32 in. Aveis flat sreen tv or to know who makes Aveis tv. Thank you!
Aveis is a daytek product which is a Daewoo company. I found a site where you can check and make sure of this http://www.daytek.ca/ Click on products. I found codes for daewoo on page 35 of a manual I downloaded from this site:http: //tv.manualsonline.com/manuals/mfg/shaw/atlas_pvr_universal_remote_control.html . I hope this works for you.
Oct 06, 2010 | RCA Universal Remote Control
PVR locked in Standby with LED Display ''STARTING'' otherwise dead
pvr's generally just record to a hard drive if you are lucky you may be able to remove the drive and connect it to a computer and retrieve your videos (format permissive of course).
The fact that it hangs on starting suggests that perhaps it has failed to initialize software on the device.
if you are lucky there may be a way to reload the factory firmware onto the device but i am yet to see one that has been done with success.
Mar 03, 2017 | Panasonic Televison & Video
Access violation in main center exe.
Try un-installing then re-installing the software for the usb stick.
Aug 07, 2007 | KWorld PVR-TV 305U (KW-PVR-TV305U) Video...
Mustek PVR-H140 Digital Media Player Logo
90 people viewed this question
Top Mustek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
