Question about Sport & Outdoor - Others
Yamaha ttr 90 dirt bike
My sons ttr 90 is smoking real bad what do you think
Well i had the same problem with my old ttr 90 it smoked realy bad so i took off the top end an looked at the piston rings an they were fried so i bought a new piston rebuild kit an put it in an changed the oil an it ran like a champ an didnt smoke so thats what i think ur problem is
Posted on Apr 09, 2009
  • Xkaotic215x Apr 22, 2012
    How much does the pistons cost because i need to buy da same thing?
Hey when does the bike start smoking ??
Posted on Jan 03, 2009
Dirt 90 sometimes when cold doesn,t start unless u pour hot water on engine then fine after why?
Posted on Dec 20, 2009
    New Friend:
  • 41 Answers
Rebuild engine
Posted on Nov 25, 2008
Yamaha TTR 90s repair kick starter
Hi, Casey don't know if it will fit because I don't know the year of your bike, for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Yamaha ttr 90 kick start jammed
50cc KICKSTARTER PROBLEMS AND SOLUTIONS
YAMAHA TT R90 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R90 Owner Manual
Jul 14, 2017 | 2005 Yamaha TTR 90 E
Dirt bike
"something with fuel". Clean fuel filter first. If no help, clean carburetor.
Jun 23, 2014 | Motorcycles
How to replace throttle valve on ttr 90
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
TTR90 Carb Fix
YAMAHA TTR90 Owner Service Manual
May 13, 2014 | 2005 Yamaha TTR 90 E
2001 yamaha tt-r90 dirt bike kick start work an gear engage but kickstart engage engine freely
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
Kickstarter spring
Jan 25, 2014 | 2005 Yamaha TTR 90 E
Yamaha ttr90 no spark
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
TTR 90 no spark very weak spark what else should do TTR
How to fix No Spark Problem on Motorcycles and Dirt Bikes
YAMAHA TT R50E Owner Manual
May 04, 2013 | 2005 Yamaha TTR 90 E
How many hours should it take to change the shift shaft on a ttr 90 e dirt bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ttr90 shift shaft
2005 Yamaha TTR 125 Shifter Repair
Sep 19, 2012 | 2007 Yamaha TTR 90 E
How do you replace the shift lever shaft on a ttr90 dirt bike
Hi, Seng for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Replacing shift shaft
Sep 06, 2012 | 2007 Yamaha TTR 90 E
Chain size for dirt bike yamaha ttr 125
If it is a 00 - 06 Yamaha TTR125/TTR125E it is 116 link.
If it is a 00 - 06 Yamaha TTR125L/TTR125LE it is 122 link.
Mar 02, 2011 | 2003 Yamaha TT-R 125
Yamaha ttr 90 jet pilot should it be open end to
The pilot should be open. This is to say that if you look through it at a light you should be able to see through it.
I suggest blowing it out with compressed air as well as the hole it fits in. While your at it give all the jets a blow out.
once you've put it back together I also suggest you fit an in-line fuel filter.
This will help to keep the dirt out and save you having ths same problem again
Hope this helps
Regards Andrew Porrelli
Dec 08, 2009 | 2004 Yamaha TT-R 125 E
I have a Yamaha TTR 225 4 stroke that is having issues starting
Carba/f ratio needs adjusting and use of the choke will help keep the idle circuits clean.
Nov 12, 2009 | 2003 Yamaha YZ 250
Sport & Outdoor - Others Logo
1,523 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
