Hi, Click on the link below for the manual downloads.To increase the font,on the menu bar where there's 113%, click on the 'v and set to the desired font size.
I'm thinking that if the print is larger than the tape then you will need a larger tape it it is available
talk the problem out with your local office supply shop
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button. Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print" You need to do these same steps again to return the settings to Letter size again.
You did not mentioned the model or device ..but ..my suggestion ..if it is a pdf file (digital ..on he computer or on a disk ) ..just use the magnifier scale on the adobe reader and enlarge it ..It is on the top bar in the middle ..and it shows percentage ...Just choose a larger one ...or ..if it is on paper..download an on line one ...(pdf ) and reprint it .or ..scan the one you have ..and print it larger..or ..just use a copier to copy it ..but set a larger format for the job ...(all copiers have a percentage scale for the enlarging a copy job ..
Here is an easy way to make the print larger to see.
Look at the bottom right of the screen and you will see a +100%, click on the down arrow next to it and it will drop a window down so the screen print and objects will be of higher or lower magnification from 50% lower to 400 precent larger size...
Please take time to rate me
First copyand paste the link bellow intobrowserhttp://www.retrevo.com/support/Braun-7680-manual/id/23284dj382/t/2/ 2-Click on DOWNLOAD3-In the download page write your mail and security letters and click in DOWNLOAD (again). Ready, the file is an PDF whith 5,2Mb. Bye.
Go to Garmins site and find their downloads section, in there you will find the owners manual. It should be in PDF format, which you can re size to your hears or in this case eyeballs content.
Hp does not provide the hard copy of the manuals anymore..
All you can do is..
Go to hp.com/support
Select your location
select Download drivers and software
In the for product box type : the product number of your notebook located at the back "p/n"
click on the arrow beside it.
now in the search bar on top type "manuals"
You will find the PDF files
download and print..
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
A = Prints the nozzle check pattern
H = Cleans the fine cartridge
Y = Fine cartridge deep cleaning
P = prints head alignment sheet
L = prints the fine cartridge alignment sheet
U = Scans and then aligns the sheet you printed under the L option
All in the user manual in Chapter 9. Download a copy here:
