Question about Samsung HP-R5072 50 in. Plasma HDTV
Samsung LW32A23W LCD TV
I have the above 3 years old tv on the wall. Recently it developed a "white noise" type hiss at start up which disappeared after a few seconds. However now it is now there constantly. Help.....
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check out for sound module, the noise filtering system of the module is bad .replace it
Posted on Oct 11, 2008
Have a phiips tv had it in storage for over a year turned it on an the screen working perfectly but there a hising noise coming from the back of it do no what it is... Its a big bk tv not flat screen box...
hissing noise will be from high voltage regulator, i would suggest to do following:
1. switch tv off
2. remove plug from the wall
3. using air blower (compressor attachment - not leaf one!) blow the dust, especially from high voltage box section
4. connect the tv and switch on
if tv still issue hissing noise - follow 1 and 2 then:
3. remove back cover
4. use air blower again...
5. re-install back cover
6. reconnect tv and switch on
if hissing noise persist - check for blown capacitors on high voltage, replace if necessary, they have nasty tendency to pop if they are too long in storage, especially if tehy were overheated or frozen.
hope this will help you solve the problem, do not forget to vote...
Jan 27, 2015 | Televison & Video
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
I have a Samsung LN46B530 LCD TV. There are 2 parellel lines on my screen, tv is 2 years old, first started with 1 thin line in the center of the screen, now that one has gotten thicker, and another one...
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 22, 2011 | Samsung LN46B530 LCD TV
Tele wont turn out on just got light falsing on button and tickin noise
known fault samsung will fix for free they did with mine my tv was 3-4 years old they fixed it june 10 let the experts fix it
Apr 25, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Samsung HP-R5072 50 in. Plasma HDTV Logo
306 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
