Question about Dell Inspiron 1150 Notebook
Dell inspiron screen problem
Only the top half of my screen works and the bottom half is just dark with lines and stuff.
any ideas ? could i try un plugging the screen then plugging it back in ?
  • 49 Answers
-Yes you can reseat the lcd cable, follow some steps on your manuals ,If you dont have manula download the manuals from support.dell.com use your service tag. after reseating the lcd cable and still the screen is half ,try external monitor if the desktop is displaying properly may be you can consider that the lcd screen back light is damaged.try replacing the whole LCD or bring the whole system to a local store and repair the lcd back light.
Posted on Oct 11, 2008
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Dell inspiron e1505 laptop has a thin light green line on far left of screen and a thin pink line approx an inch to the right of it. Both lines run from top to the bottom of the screen. I'm assisting in...
If you were to plug it into an external display, that will tell you whether it is a VGA uProcessor fault or a screen fault. If it is a screen fault, checkout ebay for a replacement screen.
Hope that helps.
Jan 25, 2011 | Dell Inspiron E1505 Notebook
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
I have a red line in the same notebook, dell insp 1501
It's a faulty screen.
Here is how to remove old screen.
Then order new screen by DELL PART NUMBER (green), which is on the back of the screen and looks something like that:
If you will replace screen with any other (not with dell part number), then you risking, that screen will be dark and adjustment of brightness will not work.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Dropped laptop. Everything seems to work, but screen messed up
Screen cracked, you will need to order a new screen and replace it.
Here is how to replace screen on Dell Inspiron E1505.
Mar 29, 2009 | Dell Inspiron E1505 Notebook
2-3 inch swath of green from top to bottom of screen, in center
Might be a problem with your memory,your video driver,or the screens inverter board.
If you have more than 1 bank of memory,try removing one bank at a time and see if this corrects the problem. If so ,replace the bank that was removed when your screen works properly.
Also ,try updating the driver through the "Windows Update" service. If neither of those works, you may have a faulty inverter board.
Dec 28, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 2200 monitor issue
Could be that the monitor is going out, but it sounds more like a connector has worked loose or corroded and isn't making a good contact. Check and clean the screen connection, screen to inverter, and screen to motherboard.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Half of screen is not viewable
Well the issue is usally with the Video driver.Try reinstalling it from the support.dell.com and that should resolve the issue.Also you can try connectring a external moniter and see if you get the proper display on that or not.Incase you do than issue is with the screen and incase its the same on that as well than its an issue with the video card.You can get either of the two replaced accordingly.
Dec 27, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1150 Notebook Logo
248 people viewed this question
Alun Cox
