IR 5000-6000 LGL TO A4 PROBLEM
SIR,
when i am using ADF to photocopy LGL size document back to back on A4 size paper with proper reduction it is not working. original and photocopy does not match anywhere on back side.
  • panprint Nov 09, 2008
    SIR IN INDIA 95% OF WORK IS DONE IN A4 SIZE PAPER
  • Anonymous Mar 18, 2009
    sir how mach the prize photo copy IR 5000/6000 if second, if new? thank from aris indonesian. so i want buy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
What country are you from ???? here in the US we do not use A4.
Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
Posted on Oct 13, 2008
  • CheckitRight
    CheckitRight Nov 10, 2008
    OK but you said it does NOT match the back of the original? Is it still too big for the size ? what about the front side is it OK?
    Problem Solver:
  • 8 Answers
Copying LGL size cannot match with a4 size
Posted on Feb 04, 2009
A4 paper jamed in teh finsher
Go To Below official Canon Printer Page For Your problem, http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Mar 19, 2014 | Canon Ir 3300 B/w Copier image Runner...
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
Half picture when making copy in A4
A4 is not a US size if you choose A4 the paper must be that size--
US uses Ltr-- Lgl and 11X14.
Dec 11, 2012 | Sharp AR 163 Copier
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
Canon G3 model (same as ir1600), LGL size not found
oopppsss! you have to go back into service mode and reenter all the door spec from the front cover and that should get you back. But you may also have to do more service mode adj.
Apr 17, 2010 | Office Equipment & Supplies
DELETED IMAGE IN REDUCTION MODE REDUCTION A3- A4 ONLY
you must select paper size also original size on your copier,and check indicators.
Apr 05, 2010 | Toshiba e-Studio163 Copier
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
239 people viewed this question
jasbo
jasbo
