Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Ice maker makes ice, but also drips water
Water drips from front of ice maker into ice bin making huge ice clumps. I think something is cracked or a water line connection is loose.
  • John Murphy Feb 04, 2009
    I have the same problem water dripping over the side of the ice maker. Whirlpool model ED5PHEXRT00. Is it the same solution and what is the part number I need. thanks
    Scholar:
  • 42 Answers
Cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Posted on Nov 25, 2008
Makes ice but water want stop running n to ice bin
If you look above / behind your ice bin you'll notice a plastic hose wich feeds water to your ice maker. It may be loose or cracked allowing water to drip to your ice bin.
Oct 17, 2016 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
How do I fix ice maker that is dripping water from filling into the ice bin?
You will need to change the water control valve. Can you confirm the model number? Is the model LFX31925ST above your post correct? If yes this is the part=> AJU72992603 Water Inlet Valve See part location number 619-A in photo=> HERE I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | LG LFX31925ST Stainless Steel Bottom...
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Ice maker makes ice however there is a big clump of ice stuck to the bottom of the bin. It keeps happening each time I remove the clump. I have replaced the 2 valves in the back of the refrig/freeze
Sounds as if the tray is running over. Are the cubes oversized? If you remove the cover (front, usually) from the icemaker you'll probably find a fill adjustment -- a screw with + and - markings. Rotate the screw 1/2 turn in the - direction and see if you notice a reduction in cube size. If it's running over, you may need to make more than one 1/2 turn adjustment.
Jan 10, 2018 | Maytag MSD2758GEB Side by Side...
Kitchenaid superba the ice maker not filling up and making ice
dear owittione perhaps the tray if its plastic maybe its cracked and the water drains out while filling check to see if there is a clump of ice in the bin and if so replace the ice tray no if is metal maybe the same thing is happening also check for the clump of ice in the bin. Now if you dont hear any water going in the ice tray maybe the magnetic valve in the back of the fridge is bunded out or the hose from the tap to the valves has a leak or the hose from the valve to the ice tray has a leak . Check around for water puddles if formed. Those are the probable causes that can lead to your problem ofcourse if the refrigerator over all is working fine. good luck. Regards Tony.
Dec 02, 2011 | KitchenAid Superba Architect KSCS25INSS...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Something is wrong with my icemaker
check supply tube behind ice maker,make sure it is lined up to feed icemaker,also you can pull it out look inside to make sure it;s not frozen inside tube or frig. wall,thanks-mike
May 28, 2008 | Refrigerators
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
381 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
