DP-R99 Kenwood CD Player Disc 2 does not work; instead displays EE
My Kenwood DP-R99 CD Player's disc 2 of 5 does not work. When the player goes to disc 2, EE is displayed. Also occurs when trying to play disc 2 manually. I do not see any obvious damage to the CD holder. happens with all CDs placed in Disc 2.
2 Suggested Answers
SOURCE: my kenwood dp-r99 reads ee
I just took my DP-R99 out of the closet and powered it up in my garage. After a short delay it reads EE. I took it apart and the belt that drives the laser head up to the CD and pressure disk to make it spin is slipping and never raising the head enough. It looks like the belt has stretched over the years. I am now going to look for a replacement belt and the belt that rotates the carriage since it is also stretched. I will let you know for sure when I install new belts. Hope this helps...
Posted on Jul 05, 2009
smarthome2
  • 1114 Answers
SOURCE: i have a kenwood dp-r99 cd player and the cd is stuck
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Posted on Nov 07, 2009
Picks 2 disks a a time
This is a synchronization failure between the loading mechanism and the player. Could be due to worn or slipping belts or many other problems
Dec 02, 2012 | Kenwood DP-J1070 100-Disc CD Changer
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
I have a kenwood dp-r99 cd player and the cd is stuck inside with an ee message. How do I open the CD player?
Nov 07, 2009 | Kenwood CD-206 5-Disc CD Changer
My kenwood dp-r99 reads ee
Jun 06, 2009 | Kenwood CD-206 5-Disc CD Changer
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
Kenwood ddx-6019 password
i forgot my password to my kenwood ddx-6019 dvd player and the codes that you listed didn't reset it is there any other codes that might work??? or is there like a reset button that i am supposed to push please help me out
same problem
Apr 11, 2008 | Kenwood DP-R6080 5-Disc CD Changer
276 people viewed this question
 Grubhead
Grubhead
