Ignis washer/dryer AWF 592 does not complete wash cycle shows error code E 06
WONT PUMP OUT WASTE WATER
Posted on Jan 04, 2011
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
E pa au u5 5e
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
May 15, 2014 | Frigidaire Affinity FAHE4044MW 27"...
Awf 592 rattle
Sometimes the water jets spraying on tin trays etc. can make a similar noise. We've had that before.
Also, make sure the sprayer arms can spin freely - sometimes if the dishwasher has large items in it they can catch.
Mar 13, 2014 | Washing Machines
We have an Ignis awf 595 washer dryer. The machine is now beyond economical repair due to the drum shearing off its bearings. What would cause this to happen.
It would be caused by a corroded and then seized up drum bearing from a water seal leak, detergent is very corrosive and very quickly ruins the drum bearings.
Feb 06, 2012 | Maytag Washing Machines
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
User's manual for washing mashine IGNIS AWF 836 in Englisch
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 18, 2011 | Washing Machines
My hotpoint WD640G has stopped mid cycale and is showing the code? F O5 and will not complete the cycle
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 06, 2010 | Hotpoint Aquarius WD640 Front Load...
Whirlpool duet washer shows error message "F 06"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
934 people viewed this question
Top Washing Machines Experts
