My computer is a Gateway(GT4023E). When I turn it on you hear the fan come on and the orange light for the disk drive. But the blue power light doesn't come on and the monitor is blank. Tested monitor on another tower (no problems). I put the tower up for months and decided to play around with it. It started right up. Now it is back to the original problem. Please help!
  • 2 more comments
  • myford8n Nov 28, 2008
    Same GT4023E, was working fine for 1 year then does not boot up, monitor is blank but fans and disk run, but blue light does not come on. Tried replugging all device and peripherals but did not help. I actually got it to boot up once more since then, but then it went blank again. This looks like a Power Supply but I have not tried a new one.
  • smithmp753 Dec 18, 2008
    I have the same problem where the computer blue light does not come on although the fan is running. I called Gateway who said check the power supply or replace the motherboard. I read a solution provided on this website to pull powerplug off the motherboard and push in ram cards. I did this and unplugged the power supply. When I plugged everything back in it worked, until I turned off the computer again. The next time I had the problem, I just unplugged the power supply and plugged it back in. The fan came on by itself. I held down the button to shut off the computer, then pushed it on again. It came on and is working. I will check the voltage of the power supply. Otherwise, I expect the motherboard is going bad. I sure wish someone can give me a low cost, more permanent solution.
  • hummergal40 Apr 12, 2009
    I have the same problem. Going to try soluation #2. Mine also was about a year old when it happen. tried to get Gateway to help with the repairs but they said the year was over. Never buy another Gateway sorry equipment and Tech. people.
  • myford8n May 11, 2010
    There are actually two connectors on this board to the PSU, one is the 24 pin, and the other is a 4 pin connector labelled ATX 12V. Tried both but same problem.
I had this same issue late last year. Ended up replacing the mother board and system has been up and running ever since. I tried all the other ideas posted but none corrected the problem until I put in the new mother board.
Posted on Nov 30, 2008
    Problem Solver:
  • 28 Answers
This problem i have seen mostly with the d845gvad2 (series) motherboard. i myself is using it and it often happens. unplug the power supply connector from the SMPS and plug it again tightly, also press the RAM tightly, the RAM Sloth may be loose. Keep in mind, do it with the main power supply unplugged....
Posted on Oct 11, 2008
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
I turn on my tower and the fans move and the disk try clicks like it wants to spin then i turn the monitor on and it turns green them orange right away and says entering power save mode waht do i do
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds.
(Count)
Let go of the Power On button.
Do this same procedure two more times. (Or until the Power On LED does not light up anymore)
3) Plug the computer into power. WAIT 1 minute, turn the computer on.
The fans should spin at high speed for a few seconds, then settle down.
Let's see if the computer boots.
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Feb 26, 2012 | Gateway 702GE PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Monitor power light startup blue then go's to orange and screen go's black. And the power light is still orange, should it be blue?..
ou have a problem with your video card, take a look if is correctly connected and turn off the computer.
try to use your BIOS to reset it to the factory settings
Aug 11, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
Jun 23, 2009 | Gateway 500GR PC Desktop
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Orange Light permanently on motherboard. PC won't start
If all you did was change hard drive
I suspect the hard drive has been installed wrong
Ensure blue or red stripe goes to the number 1 pin on M/board and the stripe goes next to the 4 pin power supply on hard drive
Sep 23, 2008 | Computers & Internet
Orange Power light flashing
Most likely a power supply failure. It apears that the power supply is not putting out all necessary voltages.
Replace the power supply
Sep 02, 2008 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Computers & Internet Logo
684 people viewed this question
David Payne
David Payne
