Question about Amana ALG331RAW Gas Dryer
Only turns with light load
The dryer won't spin with a heavy load, but if I remove a few things, it seems to be fine. What can you advise? thx, ann
  • rlmkjones Dec 21, 2008
    same problem with whirlpool ler5620kq1. drum will not turn on heavy load like it used to do. you can take out half the load and it will work ok. It is not making any extra nosies. thanks
  • 5 Answers
If this is not turning with a heavy load it can be one of or a few different things. The motor may be going bad and cant handle the heavy load or the drum belt may be slipping or the dryer drum wheels where the dryer rides on may be worn out.
If its the wheels the machine will be making a sort of a grinding sound when it runs and the dryer drum will be loose and wobbly inside the machine. The drum wheels and belt are cheapest, probably less than 10 bucks for both.
You will need to remove the front of the machine and remove the drum to get to the wheels and belt. It shouldnt take more than 1/2 hour or so to do this job.
The motor is another thing. 150.00 for the part, hours of labor and electrical connections. Clearly not worth it unless you have access to a cheap parts supplier. Check ebay for appliance parts suppliers. They usually buy up manufacturers surplus parts and sell them for 1/2 of what they originally sold for.
Posted on Oct 11, 2008
  • 2 more comments
  • M. Farr Mar 02, 2014
    I have the same problem. I think mine is a loose belt. Is it hard to tighten? how do I go about doing it after I get the front off?
  • gzukoff Mar 02, 2014
    The belt be tightened, there is a spring loaded tensioner that over time (because of constant tension and heat) will need replacing. Looking throught the bottom access panel (in the front) and it can be seen. It is in the shape of a "z" near the motor with a wheel on it that the belt rides on. You will not have to remove the drum to replace it but it makes sense to replace the belt and wheels that the drum rides on if your getting your hands dirty already.
    Sorry, that should read the belt cannot be tightened. Its similar to a car serpentine belt tensioner.
    make sure to grease the bearing surafce the wheels ride on. I use hi temp automotive bearing grease
I don't know what my error code means and my washer won't start
I had the same problem, My issue was a small sock that was sucked into the drain tube at the bottom of the washer. The technician removed the bottom panal and drained (a lot) of water from the tubing, then the sock came out, it had been preventing the water from draining out. It didn't seem to be a difficult repair to do on your own
Dec 20, 2013 | YouTube Videos
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryer won't spin. I had something heavy in it and then it stopped spinning.
It is possible that a belt could have came off or broken. You will need to turn off power and remove rear cover to investigate.
Aug 29, 2011 | KitchenAid Dryers
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
May 07, 2011 | Whirlpool LSN2000LW Washer
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
May 01, 2010 | Amana NDG7800AW Gas Dryer
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
All lights flash when started
try a different socket and try not to use extension leads if the lights continue to flash do not worry for now . the balance problem could be uneven load . or get some one to remove top and check support springson top and dampers at bottom are still in place . and concrete weights are not loose .
Feb 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My dryer takes forever to dry clothes!
it could be the vent pipe is clogged. check that out too
Jul 05, 2017 | Maytag Dryers
F&P ED56
see if the jockey arms are hitting the drum or the capacitor is losse (if the dryer is upside down).hope this helps
Oct 20, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Amana ALG331RAW Gas Dryer Logo
1,719 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
