Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hampton bay fan, wall mount remote control
I just hooked up my new hampton bay fan and installed the wall mount remote. The light switch and fan switch both work but the variable speed control doesn't, only high speed setting, please help!
  • burrow31 Oct 27, 2008
    it's a wall mount remote not a hand held so there is no batteries any other ideas?
  • 157 Answers
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • Gene Pitts Oct 26, 2008
    Hello burrow31, did rebotting the remote help or is the problem still present?
I have a 52 inch Hampton bay fan with remote control that will not work. model AC55200 SN002469B remote #G9P2BTAUC7052T. have put new batt in remote. will work light sometimes .No fan operation
This could be a defective receiver but if you are mixing wall switch operation with pull chain operation it may be getting confused. My local "big box" retailer sells complete Hampton Bay replacements for both remote control and receiver so ultimately that may be what's needed.
Dec 12, 2017 | Hampton Bay Dryers
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
Our Hampton Bay 52 in. Ceiling fan lights will not shut off but the remotes will still turn the fan on and off.
More than you will have to replace that remote and receiver with a new one . They sell them at lowes homedepot menards. Its very easy to install the reveiver is mounted in the cover at the ceiling. Make shure you set the little dip switches in the controller and receiver to the same number before installing.Hope this helps.
Nov 05, 2010 | Hampton Bay 52 In. White Redington...
Fan remotes
mcdevito75 here, If the thermostatic switch was controlling another ceiling fan then yes it should work, it"ll have to hook up to the wall switch. I'd double check with a hardware store in the area for more advise.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Fan running & stops then goes the opposite direction
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Sep 09, 2017 | Hampton Bay 52 In. 5-Blade Fan, Aged...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
1,419 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
