Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Need help setting up a secure network.
How do I setup a secure network. I am presently using a defult network.
  • R P McMurphy Oct 13, 2008
    I tried this but i cannot get by the User Name password screen???? Is there some generic way to get in to configure the router?
    Hoping you can help
    Randall
  • D-Link Master
  • 4,338 Answers
Go to 192.168.0.1 in your browser, log into the setup page of the router. Under wireless set the SSID(network name), click apply, then go to security and set the encryption key, Click apply and log out. Then on your computer, if it is wireless, click on the wireless network icon, the when it shows your network, click connect . Then you have to put your encryption key in twice.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 11, 2008
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
How to Change The Pass
On router:
if you dont have the old Wireless password you need to conect by cable either way it is easyer by cable.
find your defult gateway on your connection to the router (if you dont know hot to do this try 192.168.1.1 its the defult network setup)
Enter the password you set or find the default password for your router here:
http://www.phenoelit-us.org/dpl/dpl.html
Then change the password in the menu, often named Settings, Wireless settings, password, security settings aso.
On Fixya: go to "My FixYa" and or "My account" then press the link "Change password" under your email.
On other webpages: Find account, account settings, my account aso.
Then change "personal settings", "email and password", "password" etc. you might get a email where you need to confirm your password change.
Aug 24, 2011 | Computers & Internet
I just changed my router password and after that I could not pernt any pages? I do send it and it just says pendin? I did reset the printer to fctury defult and set it again, it did not help me either
As you haev changed the router password, you need to connect the printer again to the network. Run the network setup wizard from the printer's menu.
Regards,
Shrey
Jun 04, 2011 | Brother HL 2140 Laser Printer
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Linksys WCG200 Router
I need password to be able to lock my internet
You can find everything you need to know from here:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
You basically setup your own security. If this is a pre-configured router and you do not know the access information, then you may need to reset the router back to factory and then configure it from scratch. While you are at it, download the latest firmware and update your router for best performance.
Apr 14, 2010 | Linksys Wireless-G WRT54G Router
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
Securing my belkin router with a network key
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.2.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is admin and password is blank (this is generic to all the belkin routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a belkin router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Feb 20, 2009 | Belkin (F5D7230-4) Router (587009)
MICROSOFT WIRELESS ROUTER
ok...
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway(default gateway should look like this 192.168.2.1)now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is blank and password is admin (this is generic to all the microsoft routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a microsoft router page,in that page you will see an option which says wireless click on wireless and then under wirless you will have the wireless security,now you need to enable the security adn choose the type of secuirty type and save the settings once you do that you wireless connection should be setup with a security code...
PS:when you make your wireless network secured make sure that the computer is connected wired to the rotuer..
vedhick
Feb 20, 2009 | Microsoft Broadband Networking MN-500...
Forgot changed security code
security code for nokia-Defult=12345
another is *#7370#
If you using samgsung mobile your defult code is 00000000
Feb 19, 2009 | Nokia Cell Phones
Linksys router
If your trying to secure you network, then in your web browser type 192.168.1.1 (private address used by Linsys) and press enter.
It will prompt you for user name and password to access your router settings. By defult both username and password are "admin". Don't type quotes.
Once your in, you can secure you network with a password.
Mar 31, 2008 | APC Password Manager 4000 (BIOCB40)...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
284 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
