Question about Whirlpool Dryers
Gsas dryer ignitor won't light
Whirlpool gas dryer model LGQ8611LW0. Just replaced the ignitor. Still will not light? Everything else appears to work. Any ideas?
  • 943 Answers
HI thanks for your question. the faulty part is a thermal fuse, located at the back. pull dryer out . remove the back panel. clean all lint . clean venting to the outside. thermal fuse is located inside the dryer, on the air duct to the Left a small piece of plastic with 2 blue wires to it. replace this part. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 11, 2008
A whirlpool gas dryer - no heat! - replaced the ignitor head ( was broken) -still no heat! thanks bernie
What is the model number of your unit?
Does the igniter glow but the unit won't light?
Nov 08, 2012 | Whirlpool Dryers
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Lgq8611lw0 dryer spins but no heat
Wow that a nice gas dryer. It features electronic drying. I would make sure the sensors are clean. They get a film of dryer sheet goop on them and the sensing board cannot read dampness and shuts down the dryer thinking the cloths are dry. So check that first. Your thermostat control has 4 wires. 2 of the smaller wires warm a small heater to change the rate of time the thermosdisc opens. Newer models have a thermister. Next to it is a thermal disc.e749f09.jpg It kills power to the gas assembly but does not kill the motor. If it is open then their won't be any heat. The next thing to check for continuity is the flame sensor.db76c0c.jpg It must have continuity. It powers up the ignitor.6c68f9d.jpg If either of these are open( no continuity) then you won't have no heat. When the control is cool it powers the gas assembly. The flame sensor and ignitor kick in. The solenoids cannot kick in because the ignitor is on. When the temp gets hot enough it bends a bi-metal inside the flame sensor and opens the circuit to the ignitor. With the flame sensor and ignitor out of the circuit the surge of power can now zap those solenoids, gas comes out hitting the ignitor, and whooosh you have flames. It only take a minute or 2 of flames to warm the dryer to 160f. Then the control shuts down the operation. So what can go wrong? If the limit is blown or the control is blown then no power can get to the gas assembly. If either the flame sensor or ignitor is bad you won't get heat finally if the heat works a little bit but no more, then replace those solenoids.83a012d.jpg They tend to fail when hot and work when cold. More Here
Even more Here
This video shows how to get into your machine:
Aug 08, 2010 | Whirlpool Dryers
I have a whirlpool GGN2000HQ0 gas dryer. Everything appears to work properly but there is no heat?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 02, 2010 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool dryer Model: lgr7646eq3 serial #:mh4104127 The unit does not generate any heat when under operation. It is a gas dryer and there doesn't appear to be a pilot light. Any recommendations?
heatman101
May 12, 2010 | Dryers
Why wont my dryer heat up
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 26, 2009 | Whirlpool LGB6300 Gas Dryer
My whirlpool gas dryer will not heat. I replaced
there is a big black box on top of the burner check this if good check theremal fuse this will be on the heat tube most likly in the back it is small and white
Jun 26, 2009 | Whirlpool Dryers
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Dryers Logo
119 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
