Indesit W 123 Front Load Washer Logo
Posted on Oct 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indesit washing machine wdg1295w blowing fuse
My washing machine blows a fuse, I think on the spin cycle. When 13amp plug fuse replaced it will run for varing amounts of time. The time is reducing, ie problem getting worse. This is an indesit wdg1295, about 5 years old. Can you help?
  • Geordierhino Oct 12, 2008
    Hi grandadfixer,
    I think you are right, how much for the brushes and delivery time? Is this machine cold water fill only? I ask as it has pipes for both hot and cold but my other half insists it is cold fill only. How do I send you my email address?
    Geordie Rhino
Anonymous
Level 2:
  • Expert 99 Answers
  • Posted on Oct 11, 2008
Anonymous
Expert
Level 2:
Answers
99
Questions
0
Helped
30859
Points
157
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
1helpful
LG WD-1265TP washing machine household electricity cut out switches off the power
I think that either:
A: you have too many things running on that circuit (space heater perhaps?) or...
B: your washing machine needs a repair.
Best of luck
The washing machine won't turn on. Nothing is flashing. Nothing is working. It stopped mid cold cycle.
Thank you for contacting Fixya.com.
Please check the following causes for your problem:-
Check whether your washing machine is getting power. Or has a fuse blown or is a circuit breaker tripped. Also if the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Please get back to us if you have any further query.
Have a nice day.
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Blown fuses
please check your fuse box, it must have 22amps fuse. if not than upgrade it.
if your fuse is of 22amps or above, than my friend you have to replace your switch...............thank you and have a nice day
1helpful
2answers
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Indesit WG1235T O
I would say the doorlock switch is faulty
2answers
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
