Question about GE Microwave Ovens
GE Blt In Microwave runs but NO SOUND and shows NO SOUND on control panel
1996 GE Turntable Microwave.  Works perfectly except if you would set timer NO sound or NO beep when it shuts off.  Or when you hit "Clear" , again NO sound.  On the window that shows time remaining to cook, etc, it also says NO SOUND.
Easy fix?  Why do I feel it's not.  Thanks!!!!
  • 706 Answers
Hello Marlenes,
A 1996 microwave that is still operating at all is the exception rather than the rule..It is possible to resolve the beeper problem but the costs associated with it probably aren't worth it. To get >11 years use from a microwave without major component failure is great.. I would just live with it.... (Your call)
Regards
Posted on Oct 11, 2008
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Turntable won't turn
The turntable probably isn't on the spinny thing and that is what makes it turn- try lifting it up and putting it back on.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turntable will not turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No longer turns
on the bottom of most units you can get to the turntable motor with some side cutters,cut the joins. pull the little flap off and there is your motor run a current through it to see if it turns(how much will say on the motor) if not turning there is your problem
Oct 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
155 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
