Question about Western Digital MyBook Pro WDG1T5000 500 GB FireWire 400 (1394a) Hard Drive
Mybook will not power up
I plugged in my mybook 500 GB external drive and the blue light did not come on like usual.  Power outlet is working.  All cables connected.  No blue light.  Help.
Same problem here....
changed cable
changed USB port
changed computer
changed power adapter
No blue light, no power on, no noise (not even a click)
Can one open the enclosure to mount the Sata HD with a USB adapter on Mac?
Posted on Oct 17, 2009
I think this is a quality issue- I have just had my drive replaced (after I had to pay to post it to Singapore...) and the new drive had died - powers up for 5 secs and then nothing.
Sounds like a warratny issue.
Posted on Oct 17, 2008
    Master:
  • 538 Answers
Hmmm...disconnect it from the computer and see if it is still unhappy at that point.
Posted on Oct 14, 2008
MyBook 500G not recognized and no files showing. RE: WD5000H1U-00 The Blue light blinks high-low-high-low-steady on when i power on the drive, there is no information on the drive and the drive now...
usually this happens when the usb controller board inside the external HDD is faulty
if you are lucky this board can be replaced with a similar one then you can get your data back
Jun 21, 2011 | Western Digital My Book Essential...
Power switch not working
is this a transformer power supply? if so get a volt meter and check output a power supply connector to see if it matches what is on the power supply as output voltage. good luck
May 19, 2010 | Western Digital 250GB MyBook External USB...
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
No blue light or connection
i had the same problem & got an error message. was told that if you use a "power strip" some times the mybook will not get enough "pure" power and that it needs it's own supply. have been using a different outlet and so far it seems to be working
Jan 02, 2009 | Western Digital My Book Essential 500GB...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
External HD not starting properly
my 500 gig mybook is clicking and not showing up at all, I am going to serioulsy lose my mind WTF!!!!
Sep 13, 2008 | Western Digital 320GB MyBook External USB...
WD mybook 500 GB
check for the file system.. from your mac go to disk utilities, file system might be corrupted
Aug 17, 2008 | Western Digital My Book Essential Edition...
MYBook 500 GB Mac Edition external
i've got the same problem, but what i am going to try is to get another sata enclosure, put it and see if it works....
some other posts online said that Western Digitals components suck and therefore the mechanism for powering up the drive easily gives up......
firstly try removing the drive from the enclosure and go get a $30 enclosure with a SATA connection....this should do the trick, if not than save up some serious cash for Professional Data Recovery guy's...it ain't cheappp !
i'll keep you posted on if it works out for me !
Jan 04, 2008 | Western Digital My Book Essential Edition...
Western Digital MyBook Pro WDG1T5000 500 GB FireWire 400 (1394a) Hard Drive Logo
271 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
