Question about Garmin GPS
Route Waypoint memory full - Garmin GPS
  • violettaw79 Oct 11, 2008
    Guru:
  • 1,894 Answers
The use a different memory card sir
thank you
Posted on Oct 11, 2008
  • dewan nafees ahmed Oct 11, 2008
    1. Need to open Maintenance Mode by pressing the lower left-hand corner of the touch screen while unit is being turned on.
    2. When the "Do you really want to start up in maintenance mode?" prompts, press the "Yes" button. (It is now okay to release the lower left-hand screen).
    3. Log on password if necessary.
    4. Press the "Clear user data".
    5. When the "Do you really want to erase all user data?" prompts, press the "Yes" button.
    6. Nuvi restarts.
    7. When the Language, voice language, timezone and daylight saving choices prompt, answer per your preference then press the "OK" button.
    8. Note 1: Recent Selection data will be deleted. Favorites as well might be deleted (did not happen to me). You must save your Favorite addresses first.
    9. Note 2: You will need to set up your bluetooth phone again.
    Final note: The Memory Full and Route Waypoint Memory Full problems have been solved using the above procedure. Also, data on the My Location tab can now be deleted. No problem so far. I will keep you posted for further developments.
    the second comment is from tech support and must work
    Genius:
  • 1,011 Answers
Dear,
here is a complete list of error with solution of your device
http://www.gpsinformation.org/dale/errors.htm
regards,
rate it only if it helps or fix
    Genius:
  • 3,422 Answers
6. Nuvi restarts.
This has a very suprising unexpected side-effect, which I am unable to comment on...
  • Priya darshan Oct 11, 2008
    This will solve your problem.If you need any more help let me know.Before rating the solution.If you are satisfied then please take a moment to accept the solution.
Comes up route waypoint memory full
That is not a problem, you want it to have free memory.
Jul 27, 2010 | Garmin nuvi 310 Car GPS Receiver
How do i change routes other than listed ex Conn to Montreal QC instead of I87 to I89
If you want to coerce the routing a bit, set an intermediate point along your preferred route. Start by setting your real destination (e.g. Montreal). Next, go back to the main menu and pick a spot along I89. Designate it as the "via" waypoint. If you usually take a break somewhere, that's a good choice. The nuvi will route you from home (CT) to the waypoint, and on to Montreal. I agree that it would be nice if one could specify preferred highways (or those to avoid), but that's not among the available features.
Nov 25, 2009 | Garmin nuvi 250W GPS Receiver
How to reroute my desination i am looking for
From browsing the manual (page 20) for your Garmin nüvi 350, it looks like you will be able to do this by creating the route in MapSource, saving it as a GPX file, and then loading it to your nuvi on an SD flash memory card.
The Nuvi 350 doesn't support custom routes. You can create waypoints (or custom POIs) for each location and manually pick waypoints as you travel, but there is no way link all the points together into a route. While you can upload a GPX file to it, it won't contain the route, just waypoints. When you pick a waypoint and tell the 350 to take you there, it's going to calculate the route based on the settings (ie, vehicle type, shortest distance, etc). It won't follow a predetermined route.
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
I get a message indicating the track memory is full. Tracking then stops. I thought the track function would continue merely overwriting the earlier track. BTW the track is fairly short...maybe only 3 hrs...
Memory all your Track ,waypoint , route on a empty CompaktFlash card. This is how its go
Insert a EMPTY card press DATA than ARCHIVE AND TRANSFARE than SAVE TO CARD choose what you want to save or save all.
Make a Factoryreset on your E120.
Your Software shoud be 5.23.
Put in your CompaktFlashcard with the DATA and choose what you want in your E 120
Jul 12, 2009 | Raymarine E120 Multifunction GPS Receiver
Entering map references manually
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Dec 01, 2008 | Garmin eTrex Legend GPS Receiver
Route waypoint memory full
from the main menu select FIND. Select WAYPOINTS, press the menu button ( bottom on LHS of unit) Select DELETE from the menu, choose what you want to delete ( e.g blue flag waypoints) and hit the enter button ( rocker on front unit). Good luck !
Oct 11, 2008 | Garmin GPS
Garmin 310 sat nav ~ "Full Memory"
first thing i would do is make sure you have the latest software and firmware
http://www8.garmin.com/support/download.jsp
Jan 15, 2008 | Garmin nuvi 350 GPS Receiver
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Memory full
Have you tried downloading the latest firmware? Sometimes this can help.
Oct 29, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
977 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
