Question about Whirlpool GH5176XPT microwave Oven
It makes a bee sound and has a burning smell.
The microwave now has a burn mark on the door and just south of the interior bottom that makes up the exterior bottom.
What is wrong?
  • William Miller
    William Miller May 11, 2010
    I'd say it's arcing due to food particles, grease, or chipped paint.
    If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
    Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's
    Does that answer seem to make sense?
  • Whirlpool Master
  • 8,973 Answers
Posted on Oct 19, 2008
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
My microwave started making a crackling sound, I saw some sparks and there was a burning smell. I looked in the unit and the smell was coming from the circular cap, which I removed and then metal disk has...
You burned up the magnetron. It is not a hard replacement but requires a few checks first. I have a tip at http://www.fixya.com/support/r4265491-replace_bad_magnetron which explains the process in detail and lists where to buy the parts you will need. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 04, 2010 | GE Microwave Ovens
When the door was closed and the microwave was started,a very loud noise with an electrical burn smell occurred. I was microwaving a small microwave safe cup of milk. The built in microwave was...
hi,smell is probably the magetron,arcing...is the inside of the microwave,any burnt marks....hv diode an magetron might be bad...possible shorted hv diode....
Nov 05, 2009 | Microwave Ovens
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Spacesaver JVM 1651 Not heating, making burning smell
Fisrt, check to be sure your missing cat it not inside the unit. IF the interior is dirty (splatters, grease, etc.) , it may inhibit the unit from working properly.
Nov 22, 2008 | GE JVM1651 Microwave Oven
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH5176XPT microwave Oven Logo
166 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
