Question about Dryers
LGB6200PQ0 whirlpool dryer
Hello Guys:
My dryer was working just fine and I notice half way through the dry cycle the dryer stopped producing heat.
What should we look for or test in order to correct the problem?
Evon - Alhambra, CA
  • 2 more comments
  • Evon Orosco Oct 11, 2008
    What does this part look like?
    and where can I get it?
    Evon - Alhambra, Ca
    do you have the part number for this?
  • veronica09 Dec 31, 2008
    My dryer hasn't been heating for the last 3 months... it takes a whole day to dry clothes. Vents were cleaned and still the dryer is not working. I am not handy... would this be very expensive to have repaired?
  • Anonymous Mar 13, 2014
    when on a drying cycle there is no heat produced in the dryer
  • 943 Answers
HI thanks for the question. the problem ie more than likely the hi- limit thermostat., located on the heater box at the top. check this part. and the reason for part failure is dirty venting, clean all venting. replace hi- limit thermo. thanks the appliance doc please rate my answer, thanks.
Posted on Oct 11, 2008
  • john gagnon
    john gagnon Oct 11, 2008
    HI. its a little disc with 2 wires to it . thanks
Whirlpool wed4815ew1. Timed Dry works, timer advances. Automatic Dry does not. Plenty of heat, clothes dry fine. Bought new timer W10185982 STILL doesn't advance
Hello David. We regret to hear about your Dryer not working on select cycles. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If that does not help then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to
Jun 08, 2017 | Whirlpool Dryers
Dryer Works but does not produce heat
I would first check to see if 240 volts is coming into the machine. The motor runs on 120 the heater need 240. If that is fine remove the rear panel and check the 2 limits and heater on the right hand side for continuity. Here is my video:
Jan 09, 2014 | Whirlpool Dryers
Dryer stop heating
Try vacuuming out the intake and exhaust vents for the burner. Lint collected there can block the burner operation. Hope this helps!
Jun 28, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Only half of the heating element works
i looked up your model andfound it to need part number 3401338, this is the heater, i cannot see howe only 1/2 of the coil is going to light, its either on and all lights or its gone bad in which case its never gonna glow, its one filament like a lightbulb as long as the filament is good its alll good. too long to dry or extendedd dry times is most likely an issue with a blocked/clogged vent hose
Dec 09, 2008 | Whirlpool Dryers
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
249 people viewed this question
Top Dryers Experts
