Question about Samsung StarGate STG-31271A Hard Drive
Operating system not found
Power buton not working. two beeps after post.
  • Anonymous Jan 24, 2009
    does not recognise hard drive
    Master:
  • 538 Answers
Dead mother board..
Posted on Oct 13, 2008
Black screen green dots
What was the last thing you did on your computer before this happened?
Did you change any system settings in the BIOS?
Did you add new software? or update any software or drivers?
Did you add any new hardware?
Is your system BIOS infected with a virus?
Because it appears that your PC is hanging up during the Power-On-Self-Test [POST]
Here's what happens; when the power is turned on, the computer BIOS [Basic Input/Output System] runs a POST (Power-On Self-Test). It is a diagnostic testing sequence that the computer runs to determine if the hardware [like the mouse, keyboard, hard drive, etc.] is working properly.
If the necessary hardware is detected and found to be operating properly, the computer begins to boot; If the hardware is not detected or is not operating properly, the BIOS issues an error message.
The error message may be a text on the display screen and/or a series of coded beeps, depending on the nature of the problem.
The series or pattern of beeps may vary...they may be in a number of long or short beeps or a mixture of long and short beeps, or even one long continuous beep, depending on what type of BIOS is installed.
Since POST runs before the computer's video card is activated or the integrated graphic chip on the main board, it may not be possible to progress to the display screen.
So if an error is detected during the POST it will halt the boot process because the hardware is essential for the computer's functions.
How many beeps do you hear during the initial POST?
You may have a burned out video chip/card; or corrupt drivers; or even an IRQ [Interrupt Request] conflict.
Nov 26, 2013 | Acer Computers & Internet
Where is reset button on PS3 afterglow wired ap1
the power buton is the reset button turn off the system and press and hold the power button until you hear 2 beeps and there you go it is now reset
Jul 10, 2013 | Video Game Consoles & Games
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Dell latitude windows 7 how to find out what the beep means
Hope this helps
Nov 27, 2012 | Dell Latitude E6520 PC Notebook
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
What does 4 beeps mean on startup?
here is a link to all the beep codes this should help you
http://www.computerhope.com/beep.htm
hope that is ok
Feb 10, 2010 | Compaq Computers & Internet
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
My E-Machines desktop just stopped working. A few weeks ago, my user was corrupted so I had to do a system restore to get to my data on hard drive. Did that and backed up to external drive and it worked...
that beep means POST.. your computer hardware is fine .. please just re install the operating systemm... before that you might want to back up the hard drive data using bartpe or some tools similar to that.. if you dont have that expertise. just re install the operating system .. you should get back to work...
remember beep meaning POST meaning your hardware is fine.. the operating system is just corrupted / broekn
May 13, 2009 | E-Machines eMachines Desktop PC
Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Mar 27, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
80 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
