My Transcend JetFlash V10 16GB USB
I cant format my flash drive due to drive is write protected, but I can’t see any physical switch…can you please help me remove or fix this problem..
please email me ramesh.sanga@ynail.com i cant write or delete any thing from my pen drive
it says that "disc is write protected can not delete file"
please help me
soon
  • 23 more comments
  • Anonymous Oct 26, 2008
  • ramyDgeek Nov 09, 2008
    it says disk is write protected cant write or delete anything from drive
  • maheshpk77 Nov 24, 2008
    i cant format my Transcend JetFlash V60 16GB drive due to drive is write protected, but I can’t see any physical switch…can you please help me remove or fix this problem. from my pen drive
    please help me
    soon
  • info405 Nov 26, 2008
    yes
  • avitardotnet Nov 29, 2008
    Using a Transcend Jetflash 16 GB (actually a 15.2 GB)and getting the same error. I tried using the firmware / jet flash recovery tool then try to reformat the usb memory stick then It gives the message "The disk is write protected." This is wrong though since there is no write protection switch on the device.
  • brijesh2222 Dec 02, 2008
    i also have same problem
  • Anonymous Dec 07, 2008
    same issue
  • Anonymous Dec 21, 2008
    Even me i have the same problem on my 16 GB jetflash
  • Anonymous Dec 27, 2008
    i was able to download the recovery tool but it won't run.. I can't access my flash.What should I do???
  • coolvampire Dec 27, 2008
    i tried recovery tool, it didn't work
  • Anonymous Dec 29, 2008
    is there any other way on how to at least reformat this flash drive??? :(
  • parsbox Jan 02, 2009
    I have exactly the same problem in a 8GB oneI also downloaded the recovery tool from transcend site but still i have the problem and after recovery i can not format the flash disk - it again says it is write protectedif someone solved this problem please email me.
  • itsurimtiyaz Jan 13, 2009
    i cant format my transcend flash drive due to drive is write protected. Can any one help in removing or fixing this problem..
  • Mellow Gold
    Mellow Gold Jan 14, 2009
    I have same problem with my Transcend 8GB JetFlash V10 USB drive is Write Protected!!!... 2 drive was appear, drive e: content my usb files and drive g: empty... I try to fix in Transcend Recovery Tool.. they erase the drive: e together all my files but the drive: g is still detected and display as removable drive and if you open it the disk is not formated... i try to format it... in format window, the format capacity appears 120TB and the others is blank... to continue message appear The disk in drive cannot be formatted... PLEASE HELP ME HOW TO SOLVE THIS PROBLEM AND USE MY TRANSCEND 8GB AGAIN....
  • Anonymous Jan 20, 2009
    i have transcend JF V60 16GB pendrive......it says...cannot copy file....disk is write protected...and i'm not able to delete any files also....please help
  • aniln04 Jan 24, 2009
    my flash drive model is TS4GJFV1.. its having write-protected problem.. I installed recovery tool. it is showing "The UFD cannot use this program to repair.."
    what shall i do to get my flash drive working
  • Anonymous Jan 30, 2009
    Me too with the write-protection thing. I didn't do anything! It just happened.
  • Anonymous Feb 22, 2009
    i cant write &read data on top of that i cant format drive,it is jus waste of mmoney and time buying ....
  • braveheart66 Mar 16, 2009
    hi guys please ghelp me i ve a problem with my usb transcend jf v60 "32 gb" and it ve very important data and now its write protect wt i do0o0o0oo0o0o0o?????
  • guntarrucis Mar 21, 2009
    how remove write protection from volume
  • Anonymous Mar 31, 2009
    There is a display that " disk is write protected".
  • Anonymous Apr 20, 2009
    Can't copy to/from or use drive can see no switch to play with!
  • mcntyuask Apr 27, 2009
    "The disk is write protected" !!! I tried to change bytes too 0 ,but it didn't worked... even I counldn't format it with ALL Partition managers and Format tools...
    it posible to format should i make it crashed :D !!!
  • Anonymous May 06, 2009
    Same problem here with my transcend JF V10 8 GB........ I think mine got virus and now write protected....... any solution?
  • abhipalanii May 19, 2009
    I HAVE THE SAME PROBLEM PLEASE HELP ME
Go to the transcend site. In the support section, click drivers/downloads. Type in your model number or search for it. Mine was a Transcend 4GB JetFlash V10 drive. So the model number was TS4GJFV10. There will be a download called Recovery Tool. Get it. Run it. That's it.
P.S: use the global download link, its faster.
-TheIVth
Posted on Dec 16, 2008
Dear Friend,
My Jetflash also writeprotected, there's no any solution for this in internet but I could solve this problem,
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
I could do it,
let others to know about this solution. Because I also suffered from this problem.
Amila--> +971559473812
asfonseka@yahoo.com
Posted on Mar 20, 2009
Use the Transcend recovery tool, it worked for me. Google it or download it from the Transcend web site.
Posted on May 30, 2009
DOWNLOAD Recovery Software and properly run it its work
Posted on Mar 18, 2009
U can use jflash password recovery tools
u can click on this link http://rs558.rapidshare.com/files/149954977/JetFlash-Recovery-Tool-v1.0.19_downarchive.rar
try it this one
by YASH-RAJ
Posted on Jun 19, 2009
Simply left click on the disk drive,and click on eject.after ejecting it.remove the card from the reader and put the card back in immediately,then try pasting a file,the first time again the error will come,but the second time u past the problem will be solved.
SIMPLE
Posted on Nov 30, 2009
Try giving it a volume label
Posted on Jan 30, 2009
My sandisk memory card of 4gb shows 0 bytes how do i format?????
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 25, 2011 | Computers & Internet
Plz help me my Transcend 4GB pendrive has been write protected. plz help me
there is commonly a small switch on the pendrive somewhere , look carefully they are small, this switch write protects the drive should you wish to protect the data against overwrites for some reason. This is common to usb key drives and memory cards.
Aug 25, 2010 | Computers & Internet
I have 2 gb pen drive but not format and not run ? why ? please solution aumchaki@yahoo.com
u usb is damged .he is not repairable purchase a new usb pen stick.
kingston is good usb stick purchase it
Apr 15, 2010 | Kingston 2GB PC2-5300 DDR2 Desktop Memory
I insert my flash drive to a computer.i connot open it because not yet format in drive d:but i try to format..the windows is not enable to format
download one of the many usb format utilities there is one from hp and there is one called winsetupfromusb open it and use the rmprepusb option
Mar 04, 2010 | Kingston 1GB PC2700 DDR DIMM Memory
The usb is reading 0GB . it's and 8GB but format doesnt works TT
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Oct 04, 2009 | Iomega StorCenter (33349)
Cannot delete file due to protected drive
a small switch on side of usb drive, data lock switch
Sep 08, 2009 | Computers & Internet
200 GB Seagate External Drive, Drive Not Formatted
I hope that the information below may be of use to you
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
Sometimes it is possible to remove the drive from the case and install it direct into a computer to double check that the drive is OK
This depends on the interface eg SATA or IDE
If the drive is clicking / pinging then this is the worst noise you could hear from a hard drive as it is usually the "Click of death"
Sep 07, 2009 | Ximeta (NDU10200CU)
Ativa 1GB flash drive not recognized by Windows
the flash drive has a fat 32 file system you must change it to a NTFS file system.
Right click on my computer. find the drive in device manager. double click it. go to policies. select optimize for performance. click ok. then go disk management.to format the drive and select ntfs in file system. I hope that helps.
Nov 19, 2008 | Computers & Internet
Freecom Password Delete
Everything is possible. Few points. Is this external hd? Did you used the software and the drivers given by the manufacturer? Which OS are you using?
Yes it is possible to erase everything on any type of the drive and start from scratch. You can do this by formatting the drive make sure you do NTFS format.
Let me know please!
Dec 12, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
15,315 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
