Question about Apple iPod nano
4gb ipod I washed my ipod. Now it powers on but won't hold a charge. Comes on and works for a few minutes, then shuts off. Change the battery?
I think u r SOL.........
Posted on Oct 11, 2008
Shuffle not working
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked.
When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Oct 15, 2012 | Apple iPod classic 6th Generation Digital...
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
My ipod was working no rpoblem last night. I left it on docking station overnight and this morning it is not working. It is like there is no power ? It wont sync either totally dead! Any ideas?
  • If an iPod appears not to turn on, check the hold switch on the device. If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
    If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds. If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
    If no battery icon appears when trying to turn on the device, try resetting the iPod. Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset
Nov 26, 2011 | Apple iPod nano
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
My ipod nano 4gb blue doesn't hold a charge. It's
If you left it sitting in the box "for a few years"...then that's why.
The battery has to be used to stimulate the "memory" of the battery. If it was charged once and never used again, then of course it is going to have a battery issue.
Nov 23, 2009 | Apple iPod nano
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
4gb nano ipod hangs
flick the hold button back and forth a few times, then, making sure that it is unlocked press and hold the menu and middle button together. hold them down until it goes dark and the apple mark comes up. hope this helps?
Aug 18, 2008 | Apple iPod nano
Ipod won't turn on 3rd generation silver
Has the battery been charged lately? If not, try charging it first and then try to turn it on. If that is not the case your ipod probably just needs to be reset. Try pressing the center button with the menu button together and hold those two buttons together for about 6-10 seconds. You should get an apple icon that comes on before you will see your menu for your applications.
May 18, 2008 | Apple iPod nano 3rd Generation
IPod nano 4gb Not working, fully charged but won't power up
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 27, 2007 | Apple iPod nano
Apple iPod nano Logo
55 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
