Question about Verbatim STORE-N-GO (95312) 8 GB Hard Drive
Changing partition on Verbatim 8Gb drive
Have an 8Gb, Verbatim, USB drive which is partitioned into a "public" and "private" (password protected) section, at roughly 4Gb each. One section is now full, whereas the other has tons of space.
How do I shift -if that is the right word- the partition to make more room for the part that is now full?
  • uklee Oct 11, 2008
    this does not appear to be a solution, as I can't even get to the instructions, where I originally allocated the space to each of the two sections.
    if I had "how to", step by step, instructions for that particular device, it may work.
    Problem is solved!
    When you open the partitioned drive, click on the "V-safe" icon. A window will pop up with a choice of languages (which is unimportant).
    Click OK. A new window will pop up which prompts you for your password. In this window is also a small button for "settings" click on this and proceed with what you want to do.
    All really quite simple, if you don't try to do things from the "public" part of the partition.
  • 1,879 Answers
Read Benimur's suggestion and give him the rate.
Partition Magic is the best option for you.
Posted on Oct 11, 2008
    President:
  • 2,712 Answers
Here are step by step instructions:
http://en.kioskea.net/faq/sujet-319-how-to-resize-a-disk-partition
Hope that helps!
    Master:
  • 505 Answers
There is no way you can extend the first partition to the second one to make space. The only option is to take back up of data from partition 1 and then recreate the partition again. This is the only resolution.
Thanks
    Brigadier General:
  • 6,966 Answers
The simplest would be to use a third party software such as Partition Magic. The long way would be to copy to your hard drive all the contents of the of the flashdisk, repartition to the sizes that you want and re-format (FAT32). Thereatfer, reload back the files.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,847 Answers
Go to device manager and disk management there you will be able change partations .
  • Legin Varghese
    Legin Varghese Oct 11, 2008
    pluge in the UBS drive into the computer.
    right click the my computer>manage>device manager>choose disk manger.
    her you the remove all the partation and and make it a single partation, as i dont see any reason why do you need partation on the usb drive.
    let me know if you any further quaries....
    Kevin
    Genius:
  • 3,422 Answers
You need to remove ALL partitions, define ONE partition, and then reformat as FAT32 for multiple system compatibility. there's a partition size limit for FAT3.If you hit the limit, then make TWO equal size partitions
My imation flash drive nano 32 gb was partition public is 4gb and private is 28gb, how can i delete the partition so that it will return to its original size of 32gb.. i partition it using the imation...
click start click on computer then right click on your imation usb drive select format
this will return it the original size but it will remove any data on it
you could try to expand the partition
click start control panel administration tools computer management disk management you should see your usb drive right click in the small partition see what options are available a delete option might be there im not sure on imation software (partition magic has this option)
hope it helps
Aug 13, 2011 | Computers & Internet
Verbatim 2 GB store n go says it has 918 MB of free space, but says 'disk is full' when I try to add files. I do not believe the store n go is partitioned. What gives?
If you can read the drive, Copy the information from it, into your computer, and format the drive, copy the files back, and it should work... also, if you have a security switch on the drive (write protection) you have to disable it.
Apr 14, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
I have a 16 gb usb store n go flash drive, divide by 8 public + 8 private zone, now how colud change the space between these 2 zone, i tried to format the drive in order to change the size of these 2...
Formatting just deletes all information that is on a disk, so if you format a drive with two partitions on it, you're only formatting the partitions, not deleting the partition
so what you want to do is delete the partition between the two drives.. or at least make one of the partitions bigger.
in Windows 7
if you go to Control Panel > Administrative Tools > Computer Management > Storage > Disk Management > right click the partition you want to make SMALLER and click Shrink Volume, then right click the partition you want to make BIGGER and then click extend volume
you have now created a smaller partition and a larger partition
in Windows XP you're gonna need a program to do this.. if you google partitioning programs you'll find heaps, a good one that was very common was called "Partition Magic"
hope this helps
Mar 30, 2011 | Verbatim Store 'n' Go USB Flash Drive,...
My 8gb verbatim is write protected. don't know how to remove it
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive.
Jan 10, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I have verbatim external drive usb 2.0. It used to function properly...but now Windows(xp) doesn't open it at all and properties reflect only 2.95MB space. Its a password protected USB and doesnt even show...
update drivers. other people are having trouble with their verbatim products not registering. If you have any more problems, like finding drivers, e-mail verbatim directly with your problem.
Sep 15, 2009 | Verbatim External, USB 2.0, 750GB...
Newly bought 2GB DataTraveler only show 1GB capacity
Did you read the emanual that is on the Kindston's website for the DataTraveller? When you use the password protection program, it logs you IN to another partition you created when you started it the first time. It logs you off of the  normal drive partition and in to the password protected partition.
Both exist on the same pen drive but can not be accessed at the same time. Try logging off using the same program or if there's such a logoff shortcut anywhere on the pendrive, yo should be back to the normal 2GB partition.
HTH,
Deboo
Dec 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Lexar Locked
this is not possible on pend drive
Jun 16, 2008 | Lexar JumpDrive Classic Portable USB Data...
Verbatim usb drive 8 gb help
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Computers & Internet Logo
398 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
