it is filling and drain water only, no rotate, no sycling , no spin by the mean of no move ..the program (timer) is working as a button only means in the filling point ok, in the drain point ok, but in between no rotating,
I dont know what happened cause day before it was working perfect, just for information recently while it goes to high speed spin, it make a noisey sound with high vibrating.
is the filter stated down of the washing machine can effect on rotating, means if the filter blocked or filled of fibers or anything may block this tube , can cause the washing machine stopes rotating . help me please .
thanks so much in advance
Comments:
Oct 11, 2008
- dear grandadfixer , no, we changed the carbon bruches, but the problem still existed .Oct 11, 2008
- no dear, we changed the carbon brushes in motor, but the problem as it is... by the way what the meaning of "Or motor has had it."???Oct 12, 2008
- thanks dear, done and helpful... we test the connections and my husband fix it.. he is electrical engineer and he fix the module perfectly .. thanks for your help .Oct 12, 2008
- last question , when we closed the covers after finishing repair , we found a small plastic cover written behind it part# 44314 it is triangle with about 10x5 cm , we dont know where it should be placed , we tried everything, but we did not find out where the right place . have you any idea???Oct 12, 2008
- so sorry for repeating the last question, I press button (post it) many time cause I thought that is not sent yet ... sorry... appreciate your help for the last question .
