Roper RAS6233KQ Top Load Washer Logo
Posted on Oct 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Putting the belt back on a roper ras6233kq1?
I have a Roper ras6233kq1 and we cant figure out where it goes back on. Help please
john gagnon
Level 3:
  • Master 943 Answers
  • Posted on Oct 11, 2008
john gagnon
Master
Level 3:
Answers
943
Questions
Helped
324004
Points
2163
HI thanks for your question. so I assume you have the dryer apart, and just don't know how to install on the pulley. . after the belt is on the drum and the belt is hanging.. double the belt and push under the idler pull y , and then on to the motor pulley. thanks . please rate my answer. thanks the appliance doc.
How do i put my roper RTW4340SQ0 tub back on its track?
could you please describe the problem you are having a little better?
There is no "track" the tub goes on.
Need belt diagram for Roper dryer RES 764 6KD2
this link http://www.repairclinic.com/Dryer-Belt-Diagrams is belt configuration of all different brank dryers,The roper is either going to be diagram H or K refer to chart to see which yours will be based on the back panel
2answers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
if your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
I am replacing a belt on a roper electric clothes dryer,the tensioner fell out while i was removing the drum and i cannot figure out how it goes back.please help
there are some slots on the floor near the motor, the tensioner sits in these slots.
look at it hard and yo will see how it goes.
Nov 03, 2009 • Dryers
2helpful
2answers
Roper Washer ras6233kq1
defective pump...remove 2 screws on console corners..flip console back...disconnect lid swich harness,,,remove the 2 brass or gold color clips on each side,, now pull cabinet towards you..you see that plastic piece with 2 black hoses replace it...onthejob
2answers
My dryer belt broke
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
